Hey Dan!
Glad to help!
Remember that this was a 'custom' kit', so variations were common place based on the purpose of the plane.
Based on the customers request and intended purpose, I would make the formers the width that fit the intended engine and the intended purpose. R/C, C/L, fixed wing, removable wing, pattern, semi-scale, stunt, foam wing, built-up wing, traditional engine bearers or R/C mount.
My Akromaster was formerly owned & built by the late Randy Hancock. It had a fixed, foam wing, Rabe rudder, and an R/C engine mount. Powered by a ST 46. Still have the ST 46. In fact, it's the same motor that powered my plane to win the Beginner's event at the NATS when I got back into C/L flying.
Sorry for the run-on......
But sometimes the 'memories' avalanche!
Back to your inquire:
Spinner backplate to leading edge is 10 1/4"
Wing chord: 10"
Flap hinge to elevator hinge: 18 1/4"
Lew's Acro here has a built-up wing and I also have an original unfinished foam wing by Truflite. Both measure 10" chord.
Hope this answers your question. If not, give me another 'shout'!
"Tight Lines!"
Wes
P.S.: Yea.....I know......
As previously mentioned in another older post, Lew would practice for an upcoming contest with the Akromaster, but usually took the Shark instead.
