Like anything in trimming, you change one thing, you often have to compensate somewhere else. You change the CG you will usually have to change the leadout location, etc. What Brett notes works fine to change the ratios between the flaps and elevator, but, as he also notes, you will probably have to change the line spacing at the handle to compensate for the now faster controls. It's a system and all trim is a matter of balancing one thing against another.
