Will some one please quot the actual rule as it pertains to internal changes. As for the quotation of things that are actual OTS models and equipment I say you have to be kidding. Monocoat is OK, modern engines are OK, ignition engines that are digitally controlled are OK. Need I go on? To just say that leading edge sheeting that is inside the model is an aerodynamic improve just doesn't cut it in my mind. You have to admit that you do every thing you can to make improvements in the OTS models. There where no 4" bellcranks in the day but they are used in our OTS models. They are in fact an aerodynamic improvement. oh they are not? than why are they being used? How about the props. They where not around in the day either. So look can't you all just see how inconsistent this all is. So then why is a ringmaster with sheeting leading edges illegal. By the way I have never seen one of the illegal ones. Show a picture of it please. Now they are saying the new Viking is not correct. It should not be allowed. I say why? My effort here is to get some consistency in our rules and the interpretation of them. It is unfortunate that there are two sets of rules but the GSCB have adopted the Pampa rules or at least some of them. I am interested in getting some reasonable replies to my comments just as have already been given.
Chuck
Will some one please quot (sic) the actual rule as it pertains to internal changes.
See Mike Keville's explanation above. Need I go on?
You don't need to but you probably will anyway.To just say that leading edge sheeting that is inside the model is an aerodynamic improve just doesn't cut it in my mind.
So you think that because the leading edge sheeting is under the covering and finish then it can't possibly have any aerodynamic effect, such as changing the approximately 20% of the leading edge of the airfoil - the most critical part? Your statement about "...just doesn't cut it in my mind." pretty much says it all from your standpoint; you apparently have little understanding of aerodynamics and don't care to learn. You have to admit that you do every thing you can to make improvements in the OTS models. There where no 4" bellcranks in the day but they are used in our OTS models. They are in fact an aerodynamic improvement. oh they are not? than why are they being used? How about the props. They where not around in the day either.
Read Keville's brief summary of the OTS rules above again (or perhaps for your first time); as long as the changes do not affect the aerodynamics (there's that word again) and are strictly internal then they are OK. Why are you having so much trouble with this concept? So look can't you all just see how inconsistent this all is.
It seems that it is mainly you who is having a problem with this...all you want is to change the rules to be what you want them to be (or do you know what you want them to be?) So then why is a ringmaster with sheeting leading edges illegal.
Again, see my statement just above. You are really going to beat this one to death, aren't you - at least until you get the answer you want which is...
Sheesh...see previous statement above; it's the leading edge sheeting! My effort here is to get some consistency in our rules and the interpretation of them. It is unfortunate that there are two sets of rules but the GSCB have adopted the Pampa rules or at least some of them. I am interested in getting some reasonable replies to my comments just as have already been given.
Reasonable...that would be what you want to hear, which is...?
