  • June 23, 2025, 02:37:23 AM
Author Topic: Leather Fillets - other sources  (Read 2732 times)
Offline Douglas Ames
« on: July 22, 2012, 10:08:00 AM »
According to Builditright's website, they are out of stock on leather fillets.
The only other source I found so far was Freeman Man. & Sup., consisting of 15 different radii. They also stock their own fillet cement. Haven't got a price quote on 100 ft length...I'm thinking their a wholesaler.
Any other sources?
 http://www.freemansupply.com/FreemanLeatherFill.htm.
AMA 656546
Re: Leather Fillets - other sources
« Reply #1 on: July 23, 2012, 11:32:09 AM »
My last leather fillet order was to Bill Sawyer's widow.  Might still possibly have some left.
Offline Joshua Harel
« Reply #2 on: July 25, 2012, 04:58:04 AM »
Just out of curiosity - what or where are these leather fillets used for? I never heard about it?
Joshua
Offline Andrew Tinsley
« Reply #3 on: July 25, 2012, 05:49:44 AM »
Hello Joshua,
As far as I am aware they are used as fillets between the wing and fuselage joints. The claimed advantages are their light weightcompared to other methods of fairing in the wing / fuselage joint.
They are not very common on this side of the pond, but they have been used for a very long time in the US. I tend to crack the leather in my boots and shoes, so I look on this technique with some doubt. Mind you many people have used them for a long time, so my fears are probably groundless. Let's face it, most of my models suffer crash damage, long before any cracks might appear!
Andrew.
BMFA Number 64862
Offline builditright
  • So happy to be alive!
« Reply #4 on: July 25, 2012, 06:03:28 AM »
Joshua
As Andrew said they are for the wing to fuse joint.
But I think the reason his shoes crack is because of the constant bending.  ;)
glue them to the plane, seal them with dope and don't bend them and they should last a lot longer.  n~
I will be ordering more in the future but not right now. sorry but I need to prioritize the funds.
Thank you and God Bless
Walter
aka/ builditright
« Reply #5 on: July 25, 2012, 09:09:25 AM »
Thanks for the enlightenment. Don't they leave a "step" or a "Ridge" on both sides of the strip?
Offline Balsa Butcher
  • High Desert Flier
« Reply #6 on: July 25, 2012, 09:14:45 AM »
On a dope finish it goes on after the clear and silkspan or polyspan. After the filler coats, (sand) primer coats (sand lightly) color coats (sand lightly) clear coats (sand and polish) it virtually disappears. Even if there is a slight trace of it it is straight and will not be noticeable or unsightly. Glad they will be available in the future-thanks Walter!  8)
Just thought of this: If you put them on before the silkspan or polyspan and run the covering up next to them the slight ridge would be mimimized further. Might do it this way next time. At any rate, they work well.  8)
« Last Edit: July 25, 2012, 10:33:20 AM by Balsa Butcher »
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #7 on: July 25, 2012, 11:57:07 AM »
As a historical note, I bought those leather fillets as far back as 1948 from a company in L.A.  They were known as "pattern maker's fillets".  Maybe some tool & die person out there will confirm this.
I've posted a few times on installing these fillets.  I use good old Ambroid or SIG glue.  I wet the leather before installing and then while the glue sets I burnish the fillet with a round tool.  This makes them nice and concave so they look much better.
Leather takes dope well, and I've never had paint pull off of the leather fillets.
The slight edge disappears after a few coats of dope/filler.
« Reply #8 on: July 25, 2012, 06:55:29 PM »
Here is the finished fillet area
no noticable edge
Walter
aka/ builditright
« Reply #9 on: July 25, 2012, 07:36:13 PM »
Wow! that is impressive. I am glad I asked - learned something new and useful. Would love to try it on my next build if a good new source will materialize. Thanks guys:)
