  • July 15, 2025, 11:35:08 AM
Author Topic: Leadout Question  (Read 1677 times)
Offline Phil Coopy
Leadout Question
« on: November 19, 2006, 12:36:37 PM »
Back in the 60's when I flew CL a lot more,  several of us used to use solid music wire for leadouts with a z bend into the bellcrank. They  functioned well and always passed pull test.   Why is it that nobody does that anymore?
Phil
Offline Tom Perry
Re: Leadout Question
« Reply #1 on: November 19, 2006, 03:15:01 PM »
Phil,
I think the solids work great,  the problem is getting a bend in one right close to the eyelet.  Impossible to fix.   HB~>
Tight lines,
Tom Perry
 Norfolk, Virginia
Offline Ward Van Duzer
« Reply #2 on: November 20, 2006, 10:58:37 AM »
Yup, I like the solids too. Just don't underdo the size!
Here is how I do the ends. This bend will work on either bellcrank, or line clip end. Just make the bellcrank end a little wider, BUT ROUND BENDS!
Note the copper sleeves, and the little turn upat the wire end to preven the copper from slipping off. Also the red paint on the down line!
Be aware that some folks don't use them because some solids have broken. Oooooops...
Offline Busby
  • ACE
« Reply #3 on: November 21, 2006, 10:43:56 AM »
They also vibrate like crazy when flying.
Its bad enough when your flying something as ugly as a TEOSASWKI that it sounds ratty as well.
Busby
Marshall Busby
« Reply #4 on: November 24, 2006, 08:52:34 PM »
I had a Humongus in my truck when the  f~ automatic transmission quit with no warning. I rented a car (Cavalier, the only thing I could get locally on short notice). The H'gus just barely fitted in the back seat, because it had cable leadouts and I could poke them back into the wing. With solids, it wouldn't have fit, and I would have not been able to go flying after work, which would have further spoiled an already miserable day.  ~~> HB~> Steve
Offline Louis Rankin
« Reply #5 on: November 25, 2006, 08:15:35 AM »
Yes, I love the solid leadouts; however, they were always getting caught on something or poking holes in other models.  I now use wire leadouts on everything.
Louis Rankin
Somerville Tennessee
AMA 10859
