  • July 05, 2025, 06:07:52 PM
Author Topic: Leadout location on an Ugly Stick  (Read 4567 times)
Online Tim Wescott
« on: December 23, 2013, 12:09:47 PM »
Where should the leadouts go on an Ugly Stick?
Offline tom brightbill
Re: Leadout location on an Ugly Stick
« Reply #1 on: December 23, 2013, 01:02:03 PM »
2" behind the servo horns! WTH !!!??
AMA 34849
Joe Just
« Reply #2 on: December 23, 2013, 01:19:23 PM »
Out the wing tip on the ugly side.
Joe
Online Tim Wescott
« Reply #3 on: December 23, 2013, 01:48:22 PM »
WTH !!!??
Whadda mean WHT?
Mark Scarborough suggested that I was building an Ugly Stick for control line, so I thought I should make sure that if I did it, I did it right.
« Reply #4 on: December 23, 2013, 01:56:57 PM »
Forget the leadouts and concentrate on the right amount of aileron travel. LL~ LL~
Don't go over 2000 rpm at idle so you can taxi properly. LL~ LL~ LL~
We'll discuss the proper way to exit a spin later on. LL~ LL~
Online RC Storick
« Reply #5 on: December 23, 2013, 03:44:47 PM »
This is for the engineers who like to hang planes (Howard et.. all) Hang the plane and move the lead outs fore and aft so you have slight outward drop at the nose. But it will fall behind the CG.
Look at this video and start at 1hr 8 min in almost to the end.
Someone had a clue!  LL~ LL~
« Last Edit: December 23, 2013, 04:11:50 PM by Robert Storick »
« Reply #6 on: December 23, 2013, 04:06:06 PM »
Isn't it really a Butt Ugly Stick if it has leadouts (anywhere)? :!
AMA 34849
« Reply #7 on: December 23, 2013, 04:20:01 PM »
   The angle is easily calculated using LINEII or Bob Reeves' LINE III, it's roughly 1.5 to 2.5 degrees on normal-sized airplanes - larger for lighter airplanes, and smaller for heavier airplanes. You also get the distance at the wingtip. Its in the ballpark of 3/4" to maybe 1 1/4 behind the CG.
    It will indeed always fall behind the CG. It's there to compensate for the rearward sag of the lines.
« Reply #8 on: December 23, 2013, 09:59:12 PM »
Tim,, please open a window when you are doping your new wing,, it seems to be affecting you ,
So much more if you are rustoleum painting ,,
Dude,, you are almost as bad as me,, LOL
Merry Christmas Tim,,
Online Tim Wescott
« Reply #9 on: December 23, 2013, 10:13:18 PM »
OK.  So -- straight out the wingtip, behind the CG to the degree indicated by LINE II.  Got it.
« Reply #10 on: December 24, 2013, 08:18:51 AM »
When  we still had the tight circle at KC City Park,  there was an individual that used to change RC pattern ships to CL.   Did pretty well with them.  Can't remember his name, but the planes were the ready to fly stuff.  Never pursued the idea myself.  MERRY CHRISTMAS
Online RC Storick
« Reply #11 on: December 24, 2013, 08:20:51 AM »
I thought I said that. But I guess we need a program to figure that out. No program will accurately give you the angle as each airplanes weight distribution is different. It will only get you close and must be finally adjusted after test flights. But what do I know.
Mike Griffin
« Reply #12 on: December 24, 2013, 08:55:39 AM »
Here is the forumla for that Tim that works every time.
They hypotenuse of the chord squared by pi is equal to the transcendental to the third power of  E= Mc2 divided by 3(3z + 4k) = 3 nano quarks x tail moment + 2.
This should do it.  n~ n~ n~ n~ n~ n~
« Reply #13 on: December 24, 2013, 12:00:07 PM »
   Bt all means, just put it anywhere, at random, and then adjust it by eye and old wives tales. I mean, whats the worst that can happen, you can run 65 mph, right?
Online Howard Rush
« Reply #14 on: December 24, 2013, 12:19:23 PM »
It's true that it will only get you close, but not because of weight distribution differences.  A rigid body having any weight distribution, but the same CG, will hang at the same angle.
« Reply #15 on: December 24, 2013, 12:28:08 PM »
     I was just happy to know that Bob has finally recognized that the CG is the reference, and not the bellcrank pivot. Small steps.
« Reply #16 on: December 24, 2013, 01:43:37 PM »
Tim,, now see what you have done,, tsk tsk,,
Online RC Storick
« Reply #17 on: December 24, 2013, 01:46:52 PM »
Let me ask you this Brett. I guess your saying that it makes no difference if the bellcrank pivot it out of the norm and centrifugal force tries to line it all up with the CG? Or does this not come into play. Also why is it the farther you move the BC back the more nose heavy the plane feels. I know why but everyone over looks these little details.
And I understand way more than you give me credit for. With the ability to build at least 4 airplanes a year I can feel the differences rather quickly as opposed to building and testing 1 plane every 10 years.
Online Howard Rush
« Reply #18 on: December 24, 2013, 02:26:05 PM »
Bob Hunt noticed that Robby's plane with the aft bellcrank location flew well.  Those of us tainted by physics know it ain't the pivot location, but if it's the case, I'd suspect it's doing something beneficial to the control linkage.  To find out what's happening you could do a 3D analysis of the control linkage.
Online Tim Wescott
« Reply #19 on: December 24, 2013, 02:37:02 PM »
Did Robby's plane have CF pushrods?  Could it just have been an increase in rigidity in the overall control system?
Online RC Storick
« Reply #20 on: December 24, 2013, 02:38:30 PM »
Here is the deal DO IT ANY WAY YOU WANT TO.
« Reply #21 on: December 24, 2013, 02:47:19 PM »
   Overlook? Nobody pays attention to this because it is absurdly wrong, you don't understand it even a little bit. I would try to explain again but you aren't listening. The airplane would have the same CG and the same "hang angle" in zero G, 1 G, or 3 Gs.
    If you really want to spend some time discussing how many airplanes - and trophies - people have, we can do that.
« Reply #22 on: December 24, 2013, 08:52:02 PM »
Seems that every one has their way of doing things.  Yes there are some that do it like others..  I know I probably have put the bell crank in the wrong place on some planes, but I never worried about it as long as the plane flew the way I wanted it to.   So instead of raising a big fuss over it, do it like 90% of the planes are done.  Now lets have a MERRY CHRISTMAS and drop the subject.  You know a search would solve a lot of problems, no matter what site  you are looking at.   I was told a long time ago, if you are showed something new, try it.  If it works that is fine,  if not store it away as it may work on a different further down the road.
Offline Perry Rose
« Reply #23 on: December 25, 2013, 05:00:53 AM »
I used an Ugly Stik 20 wing without flaps/ailerons and installed it into a Primary Force scratch built fuselage. It flew well with those numbers. I set the leadout location with a line level first and go from there.
« Reply #24 on: December 26, 2013, 02:34:39 PM »
15 degrees aft of the center of gravity.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #25 on: December 26, 2013, 03:52:10 PM »
Do you an RC ugly stick kinda like this Ultra stick that I converted to CL? This monster with a 80" span and OS-91FX for power did rather well with the CL conversion.
I put the leadout guides on the bottom of the wing tip with a 2.0 degree line rake as measured from the CG location. I never hung the model, just figured out where the CG was and then calculated the line guide location based upon the 2.0 degree line rake.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Russell Shaffer
« Reply #26 on: December 26, 2013, 04:19:03 PM »
Fred, do you have throttle control on your beast?  I like it.
Russell Shaffer
Klamath Falls, Oregon
« Reply #27 on: December 26, 2013, 07:27:30 PM »
Yes, I flew the model with 2.4Ghz controls with throttle and flaps. If I had that 91FX at full power it would have been too much. It flew at 1/3 power with that 16" prop.
The Elevator was traditional bellcrank with a dave brown fiberglass pushrod
Fred
Fred Cronenwett
