  • June 25, 2025, 07:47:13 AM
Author Topic: AMA museum needs. Thanks got it covered  (Read 1646 times)
Offline Allen Goff
  • Charter Member
    • Fellowship of Christan modelers
« on: February 05, 2022, 05:52:49 AM »
Looking for O&R .26 . I have built a Roberts Fireball for Michael Smith to use in a display for AMA’s museum. If you have one to donate send it to Michael at AMA or contact me. fcm95@comcast.net
Blessings
« Last Edit: February 19, 2022, 05:36:43 AM by Allen Goff »
Re: AMA museum needs
« Reply #1 on: February 05, 2022, 06:28:12 AM »
Allen I've searched the net for any mention of an O&R .26 with no success.  Do you think it might be the .23 you are after?  Also prewar side port or post war front rotary valve?
« Reply #2 on: February 05, 2022, 06:43:35 AM »
i flew the 23 waaaaaaaay back when, my mentor was a big O&R guy, and never mentioned a 26.
Offline afml
« Reply #3 on: February 05, 2022, 07:11:06 AM »
I have an O&R 29.
On my keypad the 6 on the number key pad is ABOVE the 3 and BELOW the 9.
Perhaps it was before his morning coffee???
Have a Blessed Day & STAY SAFE!
"Tight Lines!" H^^
Wes
Wes Eakin
Offline Peter in Fairfax, VA
« Reply #4 on: February 05, 2022, 07:49:50 AM »
So, is it a .23, .26 or .29 that is being requested?  I've got a .23 from an estate that will go live on eBay this evening.  Pic attached.
Just checked my "American Model Engine Encyclopedia" (Tim Dannels) and do not see a .26.  They have:  60, 33, 29, 23, 19, 049.
« Reply #5 on: February 05, 2022, 09:48:36 AM »
I think if you look at the original instructions they recommend the O&R .23. I think that is what Walker used even on his models he used for his "Fly 3 at the Same Time Act."
Offline Allen Goff
  • Charter Member
« Reply #6 on: February 05, 2022, 10:28:35 AM »
Gentlemen I am by no means an old time engine guy, but since this project is static only it will make no difference if it’s a 23 - 26 or 29., heck it doesn’t even have to run..Plans call for a “class B or larger.
Most of you are old time engine guys, emphasis on old guys  n~
Offline Dennis Saydak
« Reply #7 on: February 05, 2022, 11:35:18 AM »
Allen, I ain't old. Just slightly matured  ;D
You can have this .29. It's in pretty nice runable condition. I'm in Canada so send me your mailing address via P.M.
Dennis
« Reply #8 on: February 05, 2022, 05:18:28 PM »
Well if the shoe fits...........it does....
Offline Allen Goff
  • Charter Member
« Reply #9 on: February 06, 2022, 03:38:11 PM »
Thanks Dennis. H^^
« Reply #10 on: February 18, 2022, 06:20:02 PM »
Allen, there are other questions.
Spark or Glow?
Sideport or Front Rotary
« Reply #11 on: February 18, 2022, 06:57:14 PM »
Spark or Glow?
Yes. LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~ LL~
« Reply #12 on: February 18, 2022, 10:21:19 PM »
You guys haven't reached old yet. D>K
Re: AMA museum needs. Thanks got it covered
« Reply #13 on: February 19, 2022, 07:42:19 AM »
All of the walker Fireballs I have seen from the day except one, had Ohlsson 23 sideports and Walkers had two speed timers operated with a relay for switching using the lines to power the relay. They also used the tank that came mounted on the intake tube.
The one I saw that was different was in Don Stills article on the Victory, where he started with a Fireball with an Ohlsson 60 sideport. There were probably many built with other engines in the day, but the Ohlsson 23 sideport was the most often shown.
I have a couple of Ohlsson 23 sideport engines, but they are both on planes and are great running engines.  One on a scaled down Lanzo Bomber to 60" span, with a radio. To old to chase FF.
