  • June 22, 2025, 10:36:25 PM
Author Topic: Fuel Tank Problem  (Read 1666 times)
Offline Garf
    • Hangar Flying
Fuel Tank Problem
« on: November 26, 2006, 10:14:36 PM »
I am having a problem with the tanks on my Tutor 2 ARF. The original plastic clunk tank was so bad, it destroyed an engine with a 10 lap dead lean run at the end of the flight. My own Garf steel clunk tank gives me about 2 laps of a sagging run at the end. What does it take to give a clean cutoff? would muffler pressure help?
      "SAVE ALL THE PIECES"-Phil Brown
Offline fred krueger
Re: Fuel Tank Problem
« Reply #1 on: November 27, 2006, 08:12:07 AM »
Phil,
Try a low profile chicken hopper tank.  Email me or Crist Rigotti for plans.
Here's a previous thread:
http://stunthanger.com/smf/index.php?topic=2565.0
Fred
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #2 on: November 27, 2006, 09:13:04 AM »
Cock the rear of the tank out about 1/8 inch. I started doing this on all my airplanes and have a couple profiles with scary clean cutoffs. No warning at all they just quit like someone turned off the switch.
« Reply #3 on: November 27, 2006, 09:46:10 PM »
what motor?
Offline Garf
    • Hangar Flying
« Reply #4 on: November 27, 2006, 10:29:20 PM »
what motor?
ST G21 .46, TF Tutor 2 ARF
Offline Ron King
« Reply #5 on: November 28, 2006, 06:11:51 AM »
Agreed. I was also having cut out problems in the clover and a friend mentioned this trick. Two popsicle sticks tucked under the back edge of the tank worked wonders.  y1
I now build in a "ramp" for my tanks on profile fuselages. The front is recessed 1/4" and my engines fly fine.
I use GRW uniflow tanks, with no pressure - and I do get a lap or two warning, but no stutters.
Ron
Ron King
AMA AVP District 4
Wannabe Stunt Pilot since 1963
 Amateurs practice until they get it right; Pros practice until they cannot get it wrong.
