  • July 22, 2025, 04:46:46 AM
Author Topic: Last one I have,propeller  (Read 1978 times)
Offline jim gilmore
« on: July 01, 2009, 10:31:11 PM »
I know there are guys who make propellers but was curious what it would cost to duplicate the last Testors 6/3 I have. It is a kind of unique looking prop and I have no clue when or where I got it. But It does run well on a norvell .061.
Offline Roger Vizioli
  • CLiner
Re: Last one I have,propeller
« Reply #1 on: July 02, 2009, 06:32:29 PM »
Jim,
Never had one of those Testors props, so couldnot test one.
FYI - we are using APC 6x2's and having great luck, engine holds speed, doesnot load down in maneuvers. Try one if you get a chance.
Just my $.02.   :)
Roger Vizioli
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #2 on: July 02, 2009, 06:59:00 PM »
That's my prop of choice too, for the Norvel .061...APC 6x2 for stunt, 5.7x3 if you want a little more speed.  Norvels like to rev.  And I like to hear 'em.
--Ray
AMA902472
Offline George
  • Love people, Use things.
« Reply #3 on: July 02, 2009, 09:31:07 PM »
If it's the one at the top of this pic, it probably became extinct along with the Testors 8000:
George
George Bain
AMA 23454
Offline jim gilmore
« Reply #4 on: July 02, 2009, 09:47:37 PM »
Yep, thats it. If I knew how to mold one I'd mold it' I like the shape.
« Reply #5 on: July 03, 2009, 01:44:38 AM »
Try " moulding Props " on search - google .
Offline don Burke
« Reply #6 on: July 03, 2009, 07:32:14 PM »
try steve wilk, he makes ELIMINATOR props.
don Burke AMA 843
Menifee, CA
« Reply #7 on: July 04, 2009, 06:34:55 PM »
I did just exactly what Mathew Spencer suggested in his post, and quickly found this link. Looks like all the info you need.  http://members.cox.net/davidfee/PROPS.html
With Bolly going Tango Union, and Brian Eather hanging up his spurs for a few years, it looks like we might all be having to learn a new skill. A good start is getting a nice hunk of aluminum plate drilled and reamed for a slip fit for a 1/4" dowel pin (or whatever size you want for the shaft hole). I have spoken to Tom Knoppi (former F2C team member), and he says the way to make good props is to make a mold, make a prop. Correct that prop, and use it to make a better mold. Hopefully, two molds will be all you need to make. Use the same baseplate for both, duh.
The racers and speed guys don't seem to use heat to repitch their props, and may select different resins for that reason.  D>K Steve
Edit: Sorry, Jim Gilmore...I scrolled down as I wrote that post, to look at the previous posts, and took the name nearest the post to be the author of the post. What an obvious ploy that is! Take a look...you'll see what I mean.  :-[
« Last Edit: July 06, 2009, 08:02:12 PM by Steve Helmick »
Offline jim gilmore
« Reply #8 on: July 06, 2009, 02:00:08 AM »
"I did just exactly what Jim Gilmore suggested in his post, and quickly found this link. Looks like all the info you need."
What did I suggest ?
Offline Scott Jenkins
« Reply #9 on: July 06, 2009, 08:27:56 AM »
"The racers and speed guys don't seem to use heat to repitch their props, and may select different resins for that reason."
The basic reasons we do not use heat to repitch a prop are simple #1 Reheating a plastic prop (in my humble opinion) is a no no it changes the characteristics of the plastics used to make the prop and in some cases if heated too much may embrittle a prop to the point it would be dangerous to use. #2 Most carbon graphite based props are made with high end epoxys that once set are done. They do not respond to any heat treatment, again enough heat to change the pitch on a carbon based prop is way to much. Making your own molds and pitching your own props is a very satisfying experience and will help you to better understand how to get the most out of your engine regardless of whether you are flying stunt or racing or speed. Please remember that most of the props and engines used for stunt are operating at considerably lower rpm's than racing and speed people are looking for. A prop failure in these venues are usually certain death for a model due to the rpm's we are tring to achieve. Therefore good strength and sound structure and materials are paramount in making a prop for any event.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
