  • June 26, 2025, 04:23:55 AM
Author Topic: Plugs  (Read 3204 times)
Offline sadams714441
Plugs
« on: April 05, 2006, 07:08:34 AM »
What is a good plug to use with a Brodak 40 and LA 40
Steve Adams
Re: Plugs
« Reply #1 on: April 05, 2006, 07:23:09 AM »
Any good "hot" plug.
Thunderbolt is the choice around here for many.
"Hot", R/C, or 4 cycle plugs.
Re: Plugs
« Reply #2 on: April 05, 2006, 07:29:53 AM »
Thanks Bill I'll check hobby store today.  Getting ready to break both engines in.
Steve Adams
Re: Plugs
« Reply #3 on: April 05, 2006, 07:35:29 AM »
Just be sure to replace the plugs AFTER you get them broken in.  I have been told by a few engine builders in the past to do so, and I have found out first hand that they were correct.   I have seen a few engines go sour at just the wrong time if the break in  plugs were not replaced.
I have a few plugs that I use just for break in, then put a new plug in for the first flight.  If the plug goes sour on the "ground", no problem.  Cheap insurance.
Re: Plugs
« Reply #4 on: April 05, 2006, 04:39:49 PM »
Why is that?  I just had a plug die on me sometime between the 10th and 11th flight.  I had to replace the plug on the RO-Jett before I could make 11th flight.  I use Fox idle bar plugs.  DOC Holliday
Offline Russell Shaffer
Re: Plugs
« Reply #5 on: April 05, 2006, 06:58:11 PM »
I am guessing, but there could be some metal particles floating around the combustion area during the break in period?
Russell Shaffer
Klamath Falls, Oregon
Re: Plugs
« Reply #6 on: April 05, 2006, 07:04:55 PM »
Yes Right your  are  Russell
Also the plug sometimes takes a beating in breakin.
I have seen the elements kncked sideways  in engines  many times  during the  breakin
Re: Plugs
« Reply #7 on: April 05, 2006, 07:09:31 PM »
AFAIK,  it is from what Russell says.  Gunk from breakin prematurely fouling the plugs.  I hope Randy Smith chimes in on this one.  I just do what I'm told most of the time.   ;)
I'm good at learning and remembering.  I don't theorise, or investigate!  The really smart guys do all that for me.  ;D
EDIT:  Well, as I was typing, Randy DID chime in!
