  • June 15, 2025, 08:55:03 PM
Author Topic: Laser Locked Rib Update  (Read 1684 times)
Offline Bill Sawyer
« on: May 11, 2006, 07:16:38 PM »
The first picture shows the pull test bracing I have added to this plane. This allows the owner to place his hands in such a way that the full force of the pull test is applied directly to the belcrank area. This will eliminate stress on the airframe.
The second picture shows the full installation of the ribs. They fit well so I am proceeding with the project.
Bill Sawyer
AMA 53987
Windancer Models
Re: Laser Locked Rib Update
« Reply #1 on: May 13, 2006, 08:12:16 AM »
Them pictures make me even more anxious to get my hands on a kit.  DOC Holliday
« Reply #2 on: May 13, 2006, 08:42:19 AM »
Hi Bill,
This is very interesting stuff you're doing.  Been following it along.
What are you planning to use for the rear "support spar"?  Either 1/16th vertical or "uprights"?
Bill <><
Offline Jim Pollock
« Reply #3 on: May 16, 2006, 12:08:22 PM »
Bill,
I think doing uprights on each rib would be the simplest choice...Don't you??
Jim Pollock   <=  f~  %^  ;D  :o  ::)   and no, i'm not gonna do a rocket or a plane
with the icons!  ~> #^
« Reply #4 on: May 16, 2006, 04:21:27 PM »
Hi Jim,
I think the uprights are all I would do.  The span isn't that long.  It may not need anything at all.
 ;D ;D ;D ;D
 ;D ;D ;D ;D ;D
 ;D ;D ;D  ;D ;D
                      ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
                      ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D  ;D
 ;D ;D ;D  ;D  ;D
 ;D ;D ;D  ;D ;D
 ;D ;D ;D ;D
Offline Jim Pollock
« Reply #5 on: May 17, 2006, 11:32:53 AM »
Bll,
You rocket won't fly!  It doesn't have an engine powering it!
JP  :'( %^
