  • June 29, 2025, 03:52:40 PM
Author Topic: Magnum .15 XLS  (Read 889 times)
Offline John Rist
Magnum .15 XLS
« on: August 05, 2015, 03:09:07 PM »
Has anyone had any experience with the RSM Magnum .15 XLS.  AS I understand it RSM has converted it to a CL setup.
Offline eric rule
Re: Magnum .15 XLS
« Reply #1 on: August 05, 2015, 05:17:00 PM »
Hi John;
I prefer that engine over the LA.15 because it has twin ball bearings, and is a true ABC. Pop a custom designed venturi in the crank case, run a ST needle valve through the hole and you are good to go. Never had a problem with any of the ones I have sold over the years.
Eric
Offline qaz049
Re: Magnum .15 XLS
« Reply #2 on: August 05, 2015, 07:00:35 PM »
Regrettably the XLS ABC piston/Liner fit is variable. It ranges from acceptable to terrible. The OS .15 LA fits are much more reliable.
