Just One More .
TThis James Young Bellanca . ( was a V tail one F S too . ) and the Bjornwall P-51 both use replacing a rib with a identical ply one ,
With the gear leg attacked , via J bolts or whatever .
Useing the split pin method , I soak the meatal pieces in acetone . Pre Tin the lower leg / solder - if its going to be fitted later .
Use Epoxy on the holes washers etc , and a small dab at the ' split ' pin . Last one I economised , a good blob there,
but minimalist everywhere .
ALSO,
The End of the L G Wire thru the ply ( rib / mount/whatever ) Good Clout in the vive, overlength . Fit on ply, clout , Scribe Cut .
And out with the disc grinder .
( remove the leg & hold in the vise though . ) or cut & file/ dress .
As steels heavy its worth minimaliseing the quantity ,
The Soldered On lower leg , ( Throw the plane upside down , cover with old towel or whatever , Damp paper towel abot leg/wing )
easier to sheet.
Fouls less obstacles .
Adjustable hight .
Might Knock the lower leg/ whell off , to absorb impact , perhaps . ( I use 60/40 hard solder , thread of ex elec cord copper wire to bind )
likely better for knocking free with soft ( 50/50 ) solder . And not to much at that .
The Mew Gull I solderd saddles / stirrups to a aft bent main leg , hard solder . appear to hold up . Phospherous flux , 80 Wt lectricians Iron .
pre tin it all , in & out fast , or in steps , so leg inside wing dont get hot & bothered .
Trike Gear Platforms aft of spar , can be ' knock out ' with a bit of thought . keep em an inch clear of spar & t e tho , if you do .
