  • July 17, 2025, 07:15:59 AM
Author Topic: LA Blue  (Read 3027 times)
Offline Phil Coopy
LA Blue
« on: January 17, 2007, 06:10:58 AM »
How can I remove the blue finish on an LA engine ???....other than buy a different brand  ^-^
Phil
Online Paul Taylor
Re: LA Blue
« Reply #1 on: January 17, 2007, 06:32:51 AM »
Send it to me and I will remove the blue. Only problem is when you get it back, it may say Fox on the case. LL~
Love dem blue motors.
Just kidding, someone will tell you to soak it in something. I can not remember what it is.
« Last Edit: January 17, 2007, 08:57:27 AM by rootbeard »
Re: LA Blue
« Reply #2 on: January 17, 2007, 07:53:08 AM »
Do the crock pot thing as I did with my LA 40.  It seems now it will hold a needle on successive runs now.  Before it would get hot.  Might have to use scrub brush in some places.  DOC Hollliday
Offline Dick Fowler
Re: LA Blue
« Reply #3 on: January 17, 2007, 10:12:32 AM »
Phil, not sure about the crock pot answer???  The blue is paint finish, not anodized so a good paint remover works.
Dick Fowler AMA 144077
Kent, OH
Re: LA Blue
« Reply #4 on: January 17, 2007, 12:07:06 PM »
Just be careful with WHICH paint remover you use, some of them react VERY badly with aluminium (Aluminum as you guys call it) and release a toxic gas.
you can buy the LAs is natural finish......FWIW
Offline Jim Oliver
Re: LA Blue
« Reply #5 on: January 17, 2007, 02:07:01 PM »
One of my buddies works on lots of 4 wheelers, etc. also flies CLPA.  He uses auto carb cleaner to remove the blue paint from the LA engines.  He buys it at NAPA auto parts store---item number 6406.
Jim
Jim Oliver
AMA 18475
Offline Dennis Vander Kuur
Re: LA Blue
« Reply #6 on: January 17, 2007, 02:25:32 PM »
Phil,
I removed the blue paint and a lot of burnt on crud from a well used, 3rd-hand OS .46LA. It normally takes just an overnight stay in the hot antifreeze-filled crock pot to clean the burned on crud off an engine. However, that blue paint is on VERY good and it took me 3 days to get 99% of it off. The last little traces of blue paint in some corners was removed by scraping the now-softened paint out with a toothpick. The engine is now both clean and a pretty aluminum color. Hope this helps.
DennisV
Dennis L. Vander Kuur
AMA 29292
Offline roger gebhart
Re: LA Blue
« Reply #7 on: January 17, 2007, 02:42:51 PM »
I put a borrowed HP gold cup in carburator cleaner to clean it before I gave it back. I'm glad a natural finish suited the owner. Pretty embar  ass  ing but it was clean.  HB~>
Offline Phil Coopy
Re: LA Blue
« Reply #8 on: January 17, 2007, 04:10:13 PM »
Thanks folks,
I was thinking carb cleaner too..I've still got a 5 gal bucket of it I brought to FL with me........left over from my flathead engine rebuilding days...works great cleaning those 50+ year old parts.
Phil
Offline Jim Oliver
Re: LA Blue
« Reply #9 on: January 17, 2007, 05:26:59 PM »
Ha!
How about some 63 year old parts?
I have some that need refurbishing. LL~
Jim
Jim Oliver
AMA 18475
Offline Russell Shaffer
Re: LA Blue
« Reply #10 on: January 17, 2007, 06:23:47 PM »
Burn it off with a propane torch?
Russell Shaffer
Klamath Falls, Oregon
Offline Peter Nevai
    • C3EL
Re: LA Blue
« Reply #11 on: January 19, 2007, 06:14:54 PM »
soak in Dot3 brake fluid for a day or two. Repeat as necessary
Offline Frederick Fielder
Re: LA Blue
« Reply #12 on: January 19, 2007, 07:36:49 PM »
So buy a Fox! All of mine run just fine and no blue paint to worry with.
Frederick
Offline Jim Oliver
Re: LA Blue
« Reply #13 on: January 19, 2007, 09:41:09 PM »
My buddy just told me that the last batch of NAPA 6406 carb cleaner isn't the same as his older batch.  The new 6406 doesn't take the blue off.  He said it doesn't even smell the same as the old stuff.
Big Brother is looking out for us!
Jim
Jim Oliver
AMA 18475
Re: LA Blue
« Reply #14 on: January 20, 2007, 09:29:11 AM »
Ha!
Jim
Hi Jim,
My "parts" ain't quite that old yet, but I wish I could "replace" some of the ones that are "missing'! **)
Bill <><
