  • June 21, 2025, 08:13:09 AM
Author Topic: PROFILE PLANE JIG  (Read 2261 times)
Offline raby fink
PROFILE PLANE JIG
« on: February 16, 2009, 06:57:53 AM »
I have a great profile plane jig that may help those of you who have profiles. Go to the hardware store and buy a large wood clamp with the two screw handles. It lays flat on the bench and the fuselage fits perfect and can be held upright or inverted when you need to work. Hope this helps
Raby
Offline sleepy gomez
Re: PROFILE PLANE JIG
« Reply #1 on: February 16, 2009, 09:43:23 AM »
I use a vise with padded jaws.  It does the same thing
« Reply #2 on: February 16, 2009, 11:22:33 AM »
I'm using my normal fuse jig. Seems to work.
« Reply #3 on: February 16, 2009, 08:20:48 PM »
Raby
Improvising will get you everywhere! ;D
Offline Russell Shaffer
« Reply #4 on: February 19, 2009, 06:13:26 PM »
These things work pretty well, too.  This one is a Black and Decker Workmate, but I have two others that were much cheaper.  Mine came from Checker/Shucks/Kragen auto parts, but other outfits have them. I don't have room on my bench for Raby's clamp idea.
Russell Shaffer
Klamath Falls, Oregon
« Reply #5 on: February 19, 2009, 06:15:37 PM »
Randy, could you please post a photo of your fuselage jig?  I have ambitions to build something besides a profile.  Thanks.
Russell Shaffer
Offline Geoff Goodworth
« Reply #6 on: February 19, 2009, 11:51:33 PM »
G'day Russell
Work Mates are pretty useful when building but Howard Sullivan designed a pretty useful fuselage jig as well.
Find the details here: http://www.nwrcc.com/viewpage.php?page_id=20
Regards, Geoff
« Reply #7 on: February 20, 2009, 08:19:26 AM »
Russell,
Mine's pretty simple. There are a lot of examples on the board here. Here is the one Ty posted. My upright are made of metal angle stock, but it's the same idea.
http://stunthanger.com/smf/index.php?topic=650.0
http://stunthanger.com/smf/index.php?topic=5811.0
« Reply #8 on: February 20, 2009, 09:25:39 AM »
Thanks guys.  I will have to build one of these.  Sure beats the eyeball method.
Russell Shaffer
« Reply #9 on: February 20, 2009, 02:23:53 PM »
Russell,
One of the things you learn as you build these things is, don't do anything without a jig or hard surface. Use sanding blocks and do the minimum sanding with just your hand. Build stuff in jigs as much as you can. While using the Mark I Eyeball is usually good, it's important to compliment that with an actual scale.   ;D
« Reply #10 on: February 20, 2009, 08:08:26 PM »
Yeah, Randy, I actually just built my first wing with a jig.  Kind of fidelly, but it came out STRAIGHT.  It was a revelation.  Guess I'll have to join the 21st century and at least try to do it right.  The holes in the ribs are still ugly, though.
Russell Shaffer
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #11 on: February 20, 2009, 10:06:12 PM »
Fuse jigs for profiles? Are you guys having alignment problems on profile fuselages?
I've never seen it as a problem, even when I was doing simple balsa sheet ones.
I do clamp the laminated nose between two sanding blocks while the epoxy cures,
but it is not to remedy any straightness problems. (Maybe I'm preventing them?)
Maybe I'm just talking about larger (.35 sized and up) profile ships. Or maybe my
some of my profiles were actually twisted fuselages and I didn't notice. I lack the
refinement to tell.
I know it never hurts to have something straight.. ;->
Boat drinks,
L.
"Don't gamble; take all your savings and buy some good stock
and hold it till it goes  up, then sell it. If it don't go up,
don't buy it." -Will Rogers
