  • June 24, 2025, 12:55:53 AM
Author Topic: Supporting rear exhaust mufflers  (Read 856 times)
Offline Paul Allen
« on: September 20, 2019, 02:50:59 PM »
Guy's need some idea's on how to suport a rear exhaust muffler,what material could I use?
Any pictures would be great.
Re: Supporting rear exhaust mufflers
« Reply #1 on: September 20, 2019, 04:54:15 PM »
   I would start with a typical tuned pipe mount that fits,, and build a light structure of the proper height. That should be all you need. The muffler won't get too hot if you have some air flowing through the area.
Offline Don Jenkins
« Reply #2 on: September 21, 2019, 06:36:50 AM »
This is what I came up with for a PA .75 with a Kaz CF Muffler in a Dreadnought.  The muffler rests on the plywood platform and I use a high temperature o-ring captured by the 1/16 inch music wire hooks which is sandwiched between the plywood with epoxy.  Not shown in this photo, I also coated the plywood and bottom of the fuel tank with a heat proof ceramic coating just to ensure I wouldn't melt the tank but I'm pretty sure CF dissipates heat quite well.  In another plane with a Stalker .61 with a metal tank and a 1/16 inch plywood "tank floor" I made a similar 1/16 inch music wire hook sandwiched between plywood and epoxied vertically to the floor with a round seating surface for the muffler and glued a piece of split fuel tubing to the support for a cushion.  I used a spring that I had to secure it, but later went to the high temp o-rings.  Sorry no pics of this set up with cowl removed.  Hope this helps.
Don
Offline Paul Allen
« Reply #3 on: September 21, 2019, 06:00:10 PM »
Thanks Dan and Don,get the idea.
in OZl
