  • June 15, 2025, 02:22:55 AM
Author Topic: "LUCKY" Horn Boxes ?  (Read 1937 times)
Offline Rob Killick
« on: April 19, 2006, 08:38:31 PM »
I'm just looking through my RSM "Lark" plans and I've come across an item on the plans calling for "LUCKY" boxes for the flap hinges .
The flaps and elevator are built up asemblies , but I'm not familiar with the "LUCKY" boxes .
Ummmm ,
What are they ?
I'm sure they are mentioned in the "build" booklet , but I'm not sure , as I don't have it handy right now ...
« Last Edit: April 19, 2006, 09:09:37 PM by Rob Killick »
Rob Killick , MAAC 33300
Offline Charlie Pate
Re: "LUCKY" Horn Boxes ?
« Reply #1 on: April 19, 2006, 09:23:38 PM »
Lucky Boxes are a sort of rectangular box that allows you to use one  flap horn on a swept forward trailing edge in a wing.
It allows the arms to slide from side to side in the flap as it is moved up and down eleminating binding and springiness (such a word)and helps to make smooth accurate controls on a plane with swept forward trailing edge .
 Hope this helps -- best I can do !
« Reply #2 on: April 19, 2006, 11:17:20 PM »
In the case of RSM kits, he supplies parts to build a reinforced box around the flap horns arms that is built into the flap.  It basically allows for free movement and flap tweaks.  The kit should have a couple pieces of composite and maybe plywood in the hardware kit for this.
« Reply #3 on: April 19, 2006, 11:22:49 PM »
Sorry for the fuzzy picture but you should be able to make out the boxes in the hardware package.  Basically the U-shaped basswood? piece is the middle, the composite material makes up the top and bottom.
Offline Rob Killick
« Reply #4 on: April 19, 2006, 11:30:49 PM »
Thank you , both m for the greatr descriptions and the photos , too :)
You've both , opened my eyes  ;D
