  • June 21, 2025, 07:06:03 AM
Author Topic: Legacy .60 build  (Read 2167 times)
Offline Stephen
  • Stephen Hollier 217629
Legacy .60 build
« on: December 18, 2020, 10:40:38 AM »
So guys I have a couple questions. In the near future I will begin building a Lagacy .60. I notice the Brodak kit uses the leveling bar method to build the wing. I've used this method with great success in the past however I would like some alternative methods.
Next question, I plan on purchasing a RO-Jett .75 for the plane, do you think this is too much power?
Thanks guys !
Offline Perry Rose
Re: Legacy .60 build
« Reply #1 on: December 18, 2020, 11:41:10 AM »
Use an Adjusto-Jig. Tape the knock outs in position and put the rod holes so you can install top and bottom spars without removing the wing from the jig. I've built two Legacy's and the wings are straight.
Online Gerald Arana
« Reply #2 on: December 18, 2020, 07:45:28 PM »
Thanks guys !
I'm using an OS VF 46 in mine and it's plenty of power.....
Jerry
« Reply #3 on: December 18, 2020, 09:27:44 PM »
You c ould just build a bigger Legacy 60 .  VD~
Offline Daniel_Munro
« Reply #4 on: December 19, 2020, 03:50:33 AM »
I built one a couple of years ago. I made a jig up that screws to a flat bench, it has blocks that support the leading and trailing edges. Result was a nice straight and true wing. Unfortunately I cannot find any pictures. Mine was electric, with a big four cell system. I expect the .75 will haul it with ease, maybe even too much power as the Legacy doesn’t have an overly thick wing section compared to others.
NZL7396
Offline John Leidle
« Reply #5 on: December 19, 2020, 05:15:23 PM »
   The ROJETT .76 will be fine I use it in my Satona I just keep it under control.. I don't run a pipe.
         John L.
Offline JHildreth
« Reply #6 on: December 19, 2020, 09:26:32 PM »
I don't know how the SV11 compares in size with the Legacy, but I have the ROJett 76 in the SV and it works very well.  I'm sure that with the right prop and pipe length it would work well for you also.
Joe
Offline Stephen
« Reply #7 on: December 21, 2020, 09:06:19 AM »
Thanks for the feedback guys !
