Hi Lester,
The kit came with a Brodak 3" nylon bellcrank kit. The wing looks like a standard 52' Nobler wing with an extra panel, or extra 2" on the inboard wing. The bellcrank shown on the wing plan measures 2 7/8", and has no reference to the pushrod. I'll have to draw new leadouts, and reposition the leadout tubes. No problem.
The kit does come with instructions (your basic mount bellcrank with leadouts), and shows the 3" bellcrank with the pushrod in the farthest hole, or 15/16". Being a profile, and the bellcrank nut right under the fuselage, I want to get the pushrod in the right hole to avoid major surgery.
My main concern is the CG. 3 3/4". Measured at the fuselage. Is this correct for a Nobler? It shows it on the plans, and in the instructions. Wing is 9 3/4" at centerline, flaps are 2 1/2" at the widest point. Tail moment is 14 1/4".
