  • August 02, 2025, 07:25:30 AM
Author Topic: Using DC 540  (Read 1512 times)
Online RC Storick
Using DC 540
« on: July 25, 2014, 11:16:25 AM »
This would normally go in the finishing section but I get so many questions on DC 540 I want to make sure everyone see this.
MSDS
 MATERIAL SAFETY DATA SHEET
DC540
01 00
 Section 1 -- PRODUCT AND COMPANY IDENTIFICATION
PRODUCT NUMBER HMIS CODES
 Health 2*
 DC540 Flammability 4
 Reactivity 0
PRODUCT NAME
 COLORLINE™ Spray, Gray Primer
MANUFACTURER'S NAME EMERGENCY TELEPHONE NO.
 Mfd. for: NAPA (216) 566-2917
 By: THE SHERWIN-WILLIAMS COMPANY
 Cleveland, OH 44115
DATE OF PREPARATION INFORMATION TELEPHONE NO.
 13-AUG-07 (216) 566-2902
 Section 2 -- COMPOSITION/INFORMATION ON INGREDIENTS
% by WT CAS No. INGREDIENT UNITS VAPOR PRESSURE
 14 74-98-6 Propane
 ACGIH TLV 2500 ppm 760 mm
 OSHA PEL 1000 ppm
 13 106-97-8 Butane
 ACGIH TLV 800 ppm 760 mm
 OSHA PEL 800 ppm
 10 108-88-3 Toluene
 ACGIH TLV 20 ppm 22 mm
 OSHA PEL 100 ppm (Skin)
 OSHA PEL 150 ppm (Skin) STEL
 1 100-41-4 Ethylbenzene
 ACGIH TLV 100 ppm 7.1 mm
 ACGIH TLV 125 ppm STEL
 OSHA PEL 100 ppm
 OSHA PEL 125 ppm STEL
 6 1330-20-7 Xylene
 ACGIH TLV 100 ppm 5.9 mm
 ACGIH TLV 150 ppm STEL
 OSHA PEL 100 ppm
 OSHA PEL 150 ppm STEL
 1 67-63-0 2-Propanol
 ACGIH TLV 400 ppm 33 mm
 ACGIH TLV 500 ppm STEL
 OSHA PEL 400 ppm
 OSHA PEL 500 ppm STEL
 39 67-64-1 Acetone
 ACGIH TLV 500 ppm 180 mm
 ACGIH TLV 750 ppm STEL
 OSHA PEL 1000 ppm
 1 110-19-0 Isobutyl Acetate
 ACGIH TLV 150 ppm 12.5 mm
 OSHA PEL 150 ppm
Continued on page 2 DC540 page 2
 8 14807-96-6 Talc
 ACGIH TLV 2 mg/m3 as Resp. Dust
 OSHA PEL 2 mg/m3 as Resp. Dust
 1 13463-67-7 Titanium Dioxide
 ACGIH TLV 10 mg/m3 as Dust
 OSHA PEL 10 mg/m3 Total Dust
 OSHA PEL 5 mg/m3 Respirable Fraction
 Section 3 -- HAZARDS IDENTIFICATION
ROUTES OF EXPOSURE
 INHALATION of vapor or spray mist.
 EYE or SKIN contact with the product, vapor or spray mist.
EFFECTS OF OVEREXPOSURE
 EYES: Irritation.
 SKIN: Prolonged or repeated exposure may cause irritation.
 INHALATION: Irritation of the upper respiratory system.
 May cause nervous system depression. Extreme overexposure may result in
unconsciousness and possibly death.
SIGNS AND SYMPTOMS OF OVEREXPOSURE
 Headache, dizziness, nausea, and loss of coordination are indications of
excessive exposure to vapors or spray mists.
 Redness and itching or burning sensation may indicate eye or excessive
skin exposure.
MEDICAL CONDITIONS AGGRAVATED BY EXPOSURE
 None generally recognized.
CANCER INFORMATION
 For complete discussion of toxicology data refer to Section 11.
 Section 4 -- FIRST AID MEASURES
 EYES: Flush eyes with large amounts of water for 15 minutes.
 Get medical attention.
 SKIN: Wash affected area thoroughly with soap and water.
 Remove contaminated clothing and launder before re-use.
 INHALATION: If affected, remove from exposure. Restore breathing.
 Keep warm and quiet.
 INGESTION: Do not induce vomiting.
 Get medical attention immediately.
 Section 5 -- FIRE FIGHTING MEASURES
FLASH POINT LEL UEL
 Propellant < 0 F 1.0 12.8
EXTINGUISHING MEDIA
 Carbon Dioxide, Dry Chemical, Foam
UNUSUAL FIRE AND EXPLOSION HAZARDS
 Containers may explode when exposed to extreme heat.
 Application to hot surfaces requires special precautions.
 During emergency conditions overexposure to decomposition products may
cause a health hazard. Symptoms may not be immediately apparent. Obtain
medical attention.
Continued on page 3 DC540 page 3
SPECIAL FIRE FIGHTING PROCEDURES
 Full protective equipment including self-contained breathing apparatus
should be used.
 Water spray may be ineffective. If water is used, fog nozzles are
preferable. Water may be used to cool closed containers to prevent
pressure build-up and possible autoignition or explosion when exposed to
extreme heat.
 Section 6 -- ACCIDENTAL RELEASE MEASURES
STEPS TO BE TAKEN IN CASE MATERIAL IS RELEASED OR SPILLED
 Remove all sources of ignition. Ventilate the area.
 Remove with inert absorbent.
 Section 7 -- HANDLING AND STORAGE
STORAGE CATEGORY
 Not Available
PRECAUTIONS TO BE TAKEN IN HANDLING AND STORAGE
 Keep away from heat, sparks, and open flame. Vapors will accumulate
readily and may ignite explosively.
 During use and until all vapors are gone: Keep area ventilated - Do not
smoke - Extinguish all flames, pilot lights, and heaters - Turn off stoves,
electric tools and appliances, and any other sources of ignition.
 Consult NFPA Code. Use approved Bonding and Grounding procedures.
 Contents under pressure. Do not puncture, incinerate, or expose to
temperature above 120F. Heat from sunlight, radiators, stoves, hot water,
and other heat sources could cause container to burst. Do not take
internally. Keep out of the reach of children.
 Section 8 -- EXPOSURE CONTROLS/PERSONAL PROTECTION
PRECAUTIONS TO BE TAKEN IN USE
 Use only with adequate ventilation.
 Avoid contact with skin and eyes. Avoid breathing vapor and spray mist.
 Wash hands after using.
 This coating may contain materials classified as nuisance particulates
(listed "as Dust" in Section 2) which may be present at hazardous levels
only during sanding or abrading of the dried film. If no specific dusts
are listed in Section 2, the applicable limits for nuisance dusts are ACGIH
TLV 10 mg/m3 (total dust), 3 mg/m3 (respirable fraction), OSHA PEL 15 mg/m3
(total dust), 5 mg/m3 (respirable fraction).
VENTILATION
 Local exhaust preferable. General exhaust acceptable if the exposure to
materials in Section 2 is maintained below applicable exposure limits.
Refer to OSHA Standards 1910.94, 1910.107, 1910.108.
RESPIRATORY PROTECTION
 If personal exposure cannot be controlled below applicable limits by
ventilation, wear a properly fitted organic vapor/particulate respirator
approved by NIOSH/MSHA for protection against materials in Section 2.
 When sanding or abrading the dried film, wear a dust/mist respirator
approved by NIOSH/MSHA for dust which may be generated from this product,
underlying paint, or the abrasive.
Continued on page 4 DC540 page 4
PROTECTIVE GLOVES
 None required for normal application of aerosol products where minimal
skin contact is expected. For long or repeated contact, wear chemical
resistant gloves.
EYE PROTECTION
 Wear safety spectacles with unperforated sideshields.
OTHER PRECAUTIONS
 Intentional misuse by deliberately concentrating and inhaling the
contents can be harmful or fatal.
 Section 9 -- PHYSICAL AND CHEMICAL PROPERTIES
 PRODUCT WEIGHT 6.40 lb/gal 766 g/l
 SPECIFIC GRAVITY 0.77
 BOILING POINT <0 - 292 F <-18 - 144 C
 MELTING POINT Not Available
 VOLATILE VOLUME 94 %
 EVAPORATION RATE Faster than ether
 VAPOR DENSITY Heavier than air
 SOLUBILITY IN WATER N.A.
 pH 7.0
 VOLATILE ORGANIC COMPOUNDS (VOC Theoretical - As Packaged)
 Volatile Weight 46.74% Less Water and Federally Exempt Solvents
 Section 10 -- STABILITY AND REACTIVITY
STABILITY -- Stable
CONDITIONS TO AVOID
 None known.
INCOMPATIBILITY
 None known.
HAZARDOUS DECOMPOSITION PRODUCTS
 By fire: Carbon Dioxide, Carbon Monoxide
HAZARDOUS POLYMERIZATION
 Will not occur
 Section 11 -- TOXICOLOGICAL INFORMATION
CHRONIC HEALTH HAZARDS
 Ethylbenzene is classified by IARC as possibly carcinogenic to humans
(2B) based on inadequate evidence in humans and sufficient evidence in
laboratory animals. Lifetime inhalation exposure of rats and mice to high
ethylbenzene concentrations resulted in increases in certain types of
cancer, including kidney tumors in rats and lung and liver tumors in mice.
These effects were not observed in animals exposed to lower concentrations.
There is no evidence that ethylbenzene causes cancer in humans.
 Prolonged overexposure to solvent ingredients in Section 2 may cause
adverse effects to the liver, urinary, cardiovascular and reproductive
systems.
 Rats exposed to titanium dioxide dust at 250 mg./m3 developed lung
cancer, however, such exposure levels are not attainable in the workplace.
 Reports have associated repeated and prolonged overexposure to solvents
with permanent brain and nervous system damage.
Continued on page 5 DC540 page 5
TOXICOLOGY DATA
 CAS No. Ingredient Name
 74-98-6 Propane
 LC50 RAT 4HR Not Available
 LD50 RAT Not Available
 106-97-8 Butane
 108-88-3 Toluene
 LC50 RAT 4HR 4000 ppm
 LD50 RAT 5000 mg/kg
 LD50 RAT 3500 mg/kg
 1330-20-7 Xylene
 LC50 RAT 4HR 5000 ppm
 LD50 RAT 4300 mg/kg
 67-63-0 2-Propanol
 LD50 RAT 5045 mg/kg
 67-64-1 Acetone
 LD50 RAT 5800 mg/kg
 LD50 RAT 13400 mg/kg
 14807-96-6 Talc
 Section 12 -- ECOLOGICAL INFORMATION
ECOTOXICOLOGICAL INFORMATION
 No data available.
 Section 13 -- DISPOSAL CONSIDERATIONS
WASTE DISPOSAL METHOD
 Waste from this product may be hazardous as defined under the Resource
Conservation and Recovery Act (RCRA) 40 CFR 261.
 Waste must be tested for ignitability to determine the applicable EPA
hazardous waste numbers.
 Do not incinerate. Depressurize container. Dispose of in accordance
with Federal, State/Provincial, and Local regulations regarding pollution.
Continued on page 6 DC540 page 6
 Section 14 -- TRANSPORT INFORMATION
US Ground (DOT)
 May be classed as Consumer Commodity, ORM-D
 UN1950, AEROSOLS, 2.1, LIMITED QUANTITY, (ERG#126)
Canada (TDG)
 UN1950, AEROSOLS, CLASS 2.1, LIMITED QUANTITY, (ERG#126)
IMO
 May be shipped as Limited Quantity
 UN1950, AEROSOLS, CLASS 2, LIMITED QUANTITY, EmS F-D, S-U
 Section 15 -- REGULATORY INFORMATION
SARA 313 (40 CFR 372.65C) SUPPLIER NOTIFICATION
 CAS No. CHEMICAL/COMPOUND % by WT % Element
 108-88-3 Toluene 10
 100-41-4 Ethylbenzene 1
 1330-20-7 Xylene 6
CALIFORNIA PROPOSITION 65
 WARNING: This product contains chemicals known to the State of
California to cause cancer and birth defects or other reproductive harm.
TSCA CERTIFICATION
 All chemicals in this product are listed, or are exempt from listing,
on the TSCA Inventory.
 Section 16 -- OTHER INFORMATION
 This product has been classified in accordance with the hazard criteria
of the Canadian Controlled Products Regulations (CPR) and the MSDS contains
all of the information required by the CPR.
 The above information pertains to this product as currently formulated,
and is based on the information available at this time. Addition of
reducers or other additives to this product may substantially alter the
composition and hazards of the product. Since conditions of use are
outside our control, we make no warranties, express or implied, and assume
no liability in connection with any use of this information.
« Last Edit: July 26, 2014, 09:58:16 AM by Robert Storick »
Re: Using DC 540
« Reply #1 on: July 25, 2014, 11:22:14 AM »
Robert,
Nice! I am using that primer.
I'd like to see how you spray large areas like the wing.
Will you do the wing in a video?
