Finally getting a break in the weather around here to do some flying! Yes!
Got another session in on Katana today, I think thats a dozen or so flights now, plus the bench time I had on the new PA75. The fuel economy is coming up and I'm getting 6:38 on a 7.5 ounce tank now. PA75 is stock, running a T-Bolt Big Bore plug, Randy's quiet pipe and a Mejlik 13.75x4.5 flat back prop on 5% Nitro Sig fuel. (The fuel is actually a mix of 1/2 sig champ, and 1/2 sig full synth, I think it burns a little cleaner, and the plugs last longer)
This is truly a bolt it in, follow the instructions and fly package. Silky smooth. I was a little afraid it would be a thumper, turns out that was not a problem. I did make sure the front end was paid close attention to, but I didn't do anything I don't normally do, I just made sure I didn't skimp either.
Oh wait, I take that back, I did do one little thing different, but I don't think it has anything to do with the run, just longevity of the front end. I put a tiny fillet on the front and back of F1 when I had my syringe full of superfil anyways and was doing the wing and stab. Not the full length of F1, just the last little 1/2" up F1 to the cowl seam. For some reason I've had them pull away there in the past, and I thought what the heck, why not. (probably from jamming in tank shims too hard, heh, who knows.)
Couldn't be happier with the run. 1 bump starts, and 5.35 - 5.4 lap range depending on ambients. Bumped up the tip weight last week like I mentioned I would in the first post, and today I made a small handle adjustment. I haven't touched anything else since.
Just as a trim test to , I did 7 hourglasses back to back, no level laps in between, and it never backed off for a second, never sped up or slowed down, just chugged along. Woot!
Now if only the guy behind the handle could get his act together... oh well, still have some time to practice before the biggun in July.
EricV
