  • July 18, 2025, 07:27:34 PM
Author Topic: Just started covering with silk..  (Read 2597 times)
Offline Pat
« on: May 16, 2013, 12:35:00 PM »
I just started covering my Collosus with silk. MAN I love this. I may never go back to silk span!
Pat
Re: Just started covering with silk..
« Reply #1 on: May 16, 2013, 01:08:22 PM »
Pat
Ahhhhh, a convert!
Offline Jim Thomerson
« Reply #2 on: May 16, 2013, 01:08:52 PM »
I have about decided the same thing, even on 1/2A airplanes.
« Reply #3 on: May 16, 2013, 01:13:12 PM »
Silk has a few positives over silkspan, not the least of which is durability.  Much harder to poke a hole in it!  About on par with polyspan.
Offline dennis lipsett
« Reply #4 on: May 16, 2013, 01:48:23 PM »
But can cost 2X as much per package.
Dennis
Online Paul Wescott
« Reply #5 on: May 16, 2013, 01:54:29 PM »
Is anybody here buying silk in bulk to avoid the high price of silk repackaged for model airplane use?
Can someone who HAS done so provide details of what to buy and maybe a link?
Paul W.
Online Howard Rush
« Reply #7 on: May 16, 2013, 06:53:53 PM »
Offline david beazley
« Reply #8 on: May 17, 2013, 04:19:37 AM »
Both sites show different silks. Which is best for models?
AMA # 2817
Offline Rick Bollinger
  • AMA 931589
Rick Bollinger
AMA 931589
Online Howard Rush
« Reply #10 on: May 17, 2013, 11:21:21 AM »
Dharma has nice dye, too.
Offline Andrew Tinsley
« Reply #11 on: May 17, 2013, 02:12:44 PM »
Howard is correct!
The colours are vibrant and so far it has proved to be UV fast. Mind you we don't get your hot sun in the UK! I always cover with the very thin mylar that the free flight guys use. It takes a bit of practice but worthwhile as you don't need much dope to seal the silk. It produces a very light and strong covering and looks good with the Dharma dye. Not concourse, but very old time authentic looking!
Andrew.
BMFA Number 64862
Offline Gene O'Keefe
« Reply #12 on: May 18, 2013, 10:43:55 AM »
Yep, silk is my "preferred" covering for strength and long lasting - still flying a Super Chipmunk I covered with silk back in 1979 !
Gene O'Keefe
AMA 28386
Offline pipemakermike
« Reply #13 on: May 20, 2013, 03:39:04 AM »
The colours are vibrant and so far it has proved to be UV fast. I always cover with the very thin mylar that the free flight guys use. It takes a bit of practice
Andrew.
Hi Andrew
Could you talk me through the covering process as I am just about to use silk for the first time.  What do you use to fix the mylar?  Is silk best put on wet like nylon?  Where do you source your silk in the UK?
Mike Nelson
« Reply #14 on: May 20, 2013, 07:05:16 AM »
Mike   Silk can be done just like paper or you can pre wet the silk and lay it on the frame. I did that many years ago but now I just I lay the dry silk on the  bottom of the the wing and use a old hair spray bottle and get the silk very wet and dope it around the edge. Use a razor blade and trim the edges and do the top. All the methods that you have used for tissue will work. I wrap the leading edge around to the bottom but cut the trailing edge off even. The silk should be tight when dry. When I was a kid I mixed glue with dope to adhere the silk when doing complex ribs like the Ringmaster which has a concave airfoil at the back.On free flight models I always used the old method to stick the silk to the under cambered airfoil. I remember the old I beam models from the late 1950's used the glue dope mixture on each rib and I believe this added a lot of strength to the wing. I have no Idea when to get silk in Europe. Find a silk importer on line.
http://www.tradeforum.org/Silk-in-World-Markets/
Offline ericrule
« Reply #15 on: May 20, 2013, 07:30:53 PM »
Hi Pat:
You may find this article helpful.
Eric Rule
