  • July 18, 2025, 04:09:52 PM
Author Topic: Kap-Pak Fuel tanks?  (Read 850 times)
Offline Target
  • C/L Addict
Kap-Pak Fuel tanks?
« on: April 19, 2019, 11:14:10 AM »
Are the old Kap-Pak fuel tanks really brass? They say so on the box, but seems to me a metal tank from brass is a bad idea, heavy, and doesn't brass get attacked by fuel?
Maybe they are just plated to promote the adhesion of solder?
Thanks for the help!
Vr,
Target
Chris
AMA 5956
Offline Bootlegger
Re: Kap-Pak Fuel tanks?
« Reply #1 on: April 19, 2019, 08:12:09 PM »
  Didn't Acme also make round brass clunk tanks that had a telescoping tube bent in a 90 degree angle that also swiveled  ???
 Sure does seem to "rattle"  the old memory bank...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline Dave Harmon
  • Tulsa Glue Dobbers C/L and R/C Clubs AMA 5053
« Reply #2 on: April 21, 2019, 01:36:30 PM »
I think it was Demeco....Harold Debolt's company.
Not 100% on that though.....been several lifetimes ago since I had one.
Offline dale gleason
« Reply #3 on: April 21, 2019, 05:17:15 PM »
Darwin made brass tanks.
Offline dennis lipsett
« Reply #4 on: April 21, 2019, 06:15:22 PM »
material than the origional Debolt tank.
Your correct. It was made by Debolt and it was  featured on their Combateer model.I had 2 of them and they were actually really good at supplying fuel no matter the position of the model The fuel pick up swiveled freely and followed the fuel. The pick up was in the center of the tank and it had a slightly larger piece over it  The pick up tube was bent to follow the back of the tank and was slightly weighted to keep it immersed in fuel. Interestingly enough there is an RC supply Co that makes a series of tanks using the Debolt design. They are not cheap and they by all accounts are as good as the originals but better designs and material.
dennis
