  • July 11, 2025, 12:03:15 PM
Author Topic: KA 10  (Read 4100 times)
Offline Manuel Cortes
KA 10
« on: December 11, 2006, 01:13:33 AM »
Hello all.
Here are some photos of my latest creations (still in "bones").
KA 10 completely scratch built from Dixon plans, own foam cores, and will be poweres by a Super Tigre 46.
Semi sheeted Dixon concept wing.
Is the first of a pair, the second one exactly the same but still thinking the power source, depending on the Tigre 46 results.
Weight at this point is 27 oz, and I expect a final weight of 50 oz.
The only desviation form Kolesnikov design is that mine is not "all in line" because of using standard horns and want a simetric flap-elev. movement.
Hope you like it.
Offline Charlie Pate
Re: KA 10
« Reply #1 on: December 13, 2006, 11:20:05 AM »
I kept the stab line as orig on mine;and used reg. horns.
  went back and installed the offset horns.
Mine flies rather well for me. I am surprised more of these planes haven,t
Been built.
Good luck ;  let us know how it performs. y1
Re: KA 10
« Reply #2 on: December 13, 2006, 01:51:03 PM »
Hi, Charlie!!
Please, could you give some details of yours?
Engine, prop, line lenght, weigth in flight order....
Will be very apreciated, and a photo still more!!! ~>
Regards.
Next will be silkspan it..... #^
Offline Busby
  • ACE
Re: KA 10
« Reply #3 on: December 13, 2006, 02:00:45 PM »
Charlies plane has a great deal of potential, he just needs to fly it more rather than some of his antiques.
Busby
Marshall Busby
Walter Hicks
Re: KA 10
« Reply #4 on: December 13, 2006, 04:52:00 PM »
Charlie Pate is this hwat you mean by offset horns? My KA-10 Stab/el horn
Re: KA 10
« Reply #5 on: December 13, 2006, 05:38:59 PM »
Right for the stab!
Wrong! for the flap
Email me, we,ll fix it!
Re: KA 10
« Reply #6 on: December 13, 2006, 05:58:52 PM »
I would be worried as to the tiger 46 being enough for the plane.
Course, few people build as heavy as I.( I use a welder)
I have two 46 tigers and they are very sweet running , but are limited as to their
power and are easily damaged when overtaxed.
You might want to consider a ST51or make a check to see that the possible
engine change could be made with a minimum of effort while you are building.
With a 46, I believe it would be tailheavy and weight would have to be placed in the nose ,so a bigger engine wouldn,t really be a penalty.
I have a DS60 in mine with a chip muffler and it came out about the same weight as Tom,s did and balanced right on the money.
If you use the 46, I certainly hope you prove my fears foundless. ~^
Walter Hicks
Re: KA 10
« Reply #7 on: December 13, 2006, 09:40:45 PM »
KA-10 ELEVATOR HORN BENT , FLAP HORN UNBENT ,BELLCRANK
Re: KA 10 (Powerplant doubts...)
« Reply #8 on: December 14, 2006, 12:43:58 PM »
OH, my god!!!!!!!!!!!!!!!!!!!!!
Plane prior to finish and I have a doubt about power source!!!!!!!!!!!!!!!!!!!
I´m thinking in powering with a ST 51, but do you think the 46 won´t be cabable with a KA 10 in the low fifties???
I´m planing about 52-53 oz and dream with the slow graceful power of the beloved Tigre but.....
Definitely in doubt, HELP ME PLEASE!!!!
Offline Bob Reeves
    • Somethin'Xtra Inc.
Re: KA 10
« Reply #9 on: December 14, 2006, 01:13:18 PM »
Without knowing exwctly how big the KA-10 is that Tigre won't have any trouble with a 53 ounce airplane.
Offline Steve Fitton
Re: KA 10
« Reply #10 on: December 14, 2006, 03:32:57 PM »
Well, don't know about the ST-46, but my LA-46 had some trouble flying a 54 oz airplane.  This is contrary to some other findings, but that was my results at least.
Sometimes drag (wing thickness, etc) can have as much impact as weight in these areas, too.
Re: KA 10
« Reply #11 on: December 14, 2006, 04:47:14 PM »
Sorry I missed your request for my plane specs.\Here goes:
All up weight /DS60and chip muffler58-59 .oz
Line lengthAMERICAN rules dia. .018 thousand.Length65 FT.
Engine DS60 BB old version. power a plenty.Think .51 eng. would be O.K.
Prop BY%O  13" Dia' Pitch  +- 5 tune for good ole 2-4 results
Dope & silkspan Carbon Fiber gear   That gear really saves weight.
I would be delighted to send you a picture but it is resting on my other
bed in a delicate pile ,covered, among my Supermaster,Sukhoi I,TempestIIand
Staris where they are Grandchild proof.Would be delighted to send you a picture after Christmas. My Magnum, Mars,PT19,Sukhoi II ,and Charisma II are safe on the wall.
The SukhoiIII is in the top of the closet, awaiting the fuse, stab,wing and two
part body assembly(This one BETTER fly Good!Meantime-a little guitar playing
Look out WILLIE!
Re: KA 10
« Reply #12 on: December 14, 2006, 05:02:23 PM »
Bob! & Manuel!
The plane is 640 Sq .in
Org.World Champ Winning version:
weight; 1700 grams app. 591/2 ounces.
Power : 10cc/.60 . Dixon used a Vorobiev .60 then changed to xxxxx later.
Orig. had Diff. flaps . Dixon passed on that! ( Me TOO!)
Dixon attributed part of the success of the craft to the big engine and big prop
(dia.) making the wing work.
Hope this Helps
        Best regards
        Charlie Pate
Re: KA 10
« Reply #13 on: December 15, 2006, 12:15:23 AM »
Hello all!
Will think seriously in ST 51....... n~
Will tell you soon.
Regards.
Online RC Storick
Re: KA 10
« Reply #14 on: December 15, 2006, 06:44:47 AM »
The way you have the elevator horn bent is NOT a good idea. It needs to be at a 90 degree angle to the horn. This keeps the elevator movement the same on the up and down side.
Offline Bob Reeves
Re: KA 10
« Reply #15 on: December 15, 2006, 11:33:02 AM »
That is a larger airplane than I thought it would be at 53 ounces, yep at least a Tigre 51.
Re: KA 10
« Reply #16 on: December 16, 2006, 06:29:32 AM »
By the way, and checking one of the most famous ST 46 "partner", the 660 Stiletto, KA 10 performs thinner wing and sligtli more wing area.....
Express your opinions, please, people who have flown Stileto 660 with Tigre 46 suffrerd from lack of power?
Regards from Spain.
Manuel.
Walter Hicks
Re: KA 10
« Reply #17 on: December 16, 2006, 12:25:07 PM »
Hi,
    My first KA-10 was 55 oz with Double Star .60 Lite SE, flew fine . This is not a
big airplane. I had a modified Imitation that weighed 57 oz and used an LA ,46
12x5 prop the key was 12" prop. the best prop for normal conditions was one I
used on my St .46  Rev up   12x6. Obviously a plane that is too heavy should use a
larger engine. I think the idea of the KA-10 was to use a .60 and fly on the prop
I will be using a Discovery Retro .61 and or my newly arrived today Stalker .61 RE
Long Stroke . I think a lot of this is going to depend on how much your plane weighs.
Re: KA 10
« Reply #18 on: December 16, 2006, 12:53:28 PM »
Thanks for sharing your experiences, i think the same.
I´ll try a system to let easily changing St 46 and 51, and.....experiment.
Regards.
Offline Bob Reeves
Re: KA 10
« Reply #19 on: December 16, 2006, 03:19:43 PM »
Manuel, Just a hint...
I built my Skylark around a ST 46 and later swaped in a ST 51. Build it for the 51 with aluminum mounting pads and the 46 will fit, build for the 46 and you will need to do major surgery to get the 51 in. Nothing is the same on the two engnes, the 51 is larger everywhear.
Re: KA 10
« Reply #20 on: December 16, 2006, 06:09:08 PM »
I think Walter's horns will work fine for the stock KA-10 (which has wing and stab inline). It would correct the control system geometry, for this configuration, tho maybe the angle is a bit too much. If Manuel's modified KA-10 has similar horns, it would be bad news. In all cases, the control horn should be at 90 degrees to the pushrod (assuming the pushrod is straight, no doglegs allowed).  :! Steve
Re: KA 10
« Reply #21 on: December 17, 2006, 01:56:26 AM »
Stock horns in mine, 100% symetric layout.
Thanks for the advice.
Regards.
Re: KA 10
« Reply #22 on: December 18, 2006, 01:47:40 PM »
Hello all!
Will tell you soon.
Regards.
Hi Manuel,
The ST G51 is DEFINITELY the way to go if you are deciding between it and a LA46.  Having flown both, it's a "no brainer".  y1
Offline rustler
Re: KA 10
« Reply #23 on: December 18, 2006, 01:57:33 PM »
Is it my imagination or is it rather a short nose for this model? I guess an ST46 with stock silencer would be o.k.
Ian Russell.
Re: KA 10
« Reply #24 on: December 18, 2006, 02:41:08 PM »
You´re right, the nose is slightly shortened, expecting not having to add weight in the tail.... I have several silencers to play with, including old style Rustler Merco I bought you, Mr. Merco, some years ago, and are a perfect fit to ST 46.
Regards form Spain.
Manuel.
