  • June 21, 2025, 11:27:39 PM
Author Topic: T mounts  (Read 846 times)
Offline Matt Piatkowski
T mounts
« on: February 24, 2016, 08:33:56 AM »
Hello,
Please see the attachment.
Matt
Offline goozgog
Re: T mounts
« Reply #1 on: February 24, 2016, 11:01:50 AM »
Matt,
        If you get stuck, I have a pair
of extruded aluminum "T" mounts
you are welcome to.
- Firewall mounting holes spaced @ 41mm
- Over all length 76.3 mm
- Bearer thickness 9.5 mm
- Bearer length 70 mm
- Weight 30.5 g  (each)
You could drill some holes in the
webs and reduce the weight a little.
Cheers! - K.
Keith Morgan
