  • June 15, 2025, 01:55:05 AM
Author Topic: Super Pow Wow Which Engine to use ???  (Read 2795 times)
Offline Brian Thwaites
  • ACE
« on: April 12, 2006, 11:04:13 AM »
I am in the process of builing Super Pow Wow, I am at the point of deciding which engine to use I have either an LA 40 or Magnum Pro 45, the Magnum being 1.5 oz heavier than the LA. Not sure if weight would be a problem, so any thoughts would be appreciated
Brian Thwaites
Offline frank carlisle
Re: Super Pow Wow Which Engine to use ???
« Reply #1 on: April 12, 2006, 02:11:13 PM »
The Super Pow Wow has an upright engine set up doesn't it?
It's easier to adjust nose weight than tail weight. Either engine would do the job.
Frank Carlisle
  • ACE
« Reply #2 on: April 12, 2006, 08:57:39 PM »
No its mounted  inverted
Brian Thwaites
Offline Jay
  • 1 Cross +3 Nails= 4 Given
« Reply #3 on: April 12, 2006, 10:12:35 PM »
Talking about Pow Wow...  I have a Brodak Accentor on the way.  It was a great deal from EvilBay.  Anyway i was wonder what changes do I need to make so that is is a Classic Legal Pow Wow?  Someone told me that the Accentor is a direct copy of the Pow Wow.  Still would like to be sure.
Jay
My religion consists of a humble admiration of the illimitable superior spirit who reveals himself in the slight details we are able to perceive with our frail and feeble mind.
Albert Einstein
  278622
« Reply #4 on: April 12, 2006, 10:44:10 PM »
From what I've read, the Brodak kit "Accentor" is stretched in TMA and maybe NMA. I think I'd buy a good set of Pow Wow plans and compare the two plans before I made any decisions.
On the other hand, legally, you can call it a "Tucker Special" if you have the cajones, and that's all it takes to make it 'legal'. There is no clause in the rules that allows DQ for modifications. You may take a hit on the fidelity points, if they are used in your area, or appearance points, if they are not. The hit cannot be real serious. Enjoy it, and have fun.
I'd vote for the LA. You won't need more power or weight.   y1 Steve
« Reply #5 on: April 13, 2006, 06:58:28 AM »
A Pow Wow will be fine with a LA40.  How big is the "Super" Pow Wow?  That's one I cannot remember.  :o
  • ACE
« Reply #6 on: April 13, 2006, 07:20:05 AM »
specs for Super Pow Wow are wing span 52" O/Length 37.5"  550 SQ"
Brian Thwaites
« Reply #7 on: April 13, 2006, 07:35:20 AM »
LA40.  ;D
