  • July 26, 2025, 02:35:14 AM
Author Topic: just finished my Razorblade 64  (Read 1570 times)
Offline pipemakermike
« on: May 17, 2013, 03:39:33 PM »
Fitted with a Russian combat 15 so should be quite a scary model.  It has come out at 14oz and I am looking forward to flying it.
I haven't run the engine, an Ebay aquisition, yet and I understand that these engines are high revving and are best with a smaller prop than I would use on an Oliver.  The engine feels really nice when flicked over.
« Last Edit: May 17, 2013, 04:03:34 PM by pipemakermike »
Mike Nelson
Re: just finished my Razorblade 64
« Reply #1 on: May 17, 2013, 04:19:38 PM »
Very nicely done.
« Reply #2 on: May 18, 2013, 10:01:28 AM »
Great looking little combat plane of the early European designs.   Should really spin you into the ground.
Offline Gene O'Keefe
« Reply #3 on: May 18, 2013, 10:40:24 AM »
   It will turn on a dime and give you 9 cents change !
Gene O'Keefe
AMA 28386
Offline Kreth
« Reply #4 on: May 19, 2013, 01:18:54 PM »
Neat old combat model.  I like to build and fly nostalgia type combat planes.  What is the availability of plans.
What is the covering you used?
Kreth
Kreth McKee AMA 22004
« Reply #5 on: May 19, 2013, 01:28:57 PM »
Kreth
Hi Kreth
You can download the plan and the article here:-
http://www.outerzone.co.uk/plan_details.asp?ID=3236
I covered mine with nylon bought new from my local modelshop.  I think that this nylon was not the best I have used as it was very reluctant to shrink.  I put it on wet in the same way I always have but when dry it seemed to be more wrinkled than before.  It also didn't shrink much with the dope.
Mike Nelson
« Reply #6 on: May 19, 2013, 02:41:27 PM »
Was always told nylon only goes on as tight as you put it on.   It does not shrink.  But, it seems to last for ever compared to silk.
« Reply #7 on: May 31, 2013, 02:38:20 PM »
Flew it for the first time tonight.  It is scarily fast probably the fastest combat model I have ever flown and must be doing 100mph plus.  It is certainly faster than any of the rat racers I have flown.  Not only fast but turns tighter than any of the combat models I used in competition. It is also quite loud on an APC 6.3x4 prop.  I wish I had one of these when I was younger!!!!!!!!!!!
Mike Nelson
« Reply #8 on: May 31, 2013, 03:15:23 PM »
Mike that plane is from the days when "REAL MEN" flew combat. Well that sounded good what ever" REAL MEN" means. I do remember those small .15 powered combat models with super hot .15's on them. I had one or two and with 52 ft lines it was fast. I could not do it today. Have fun untill it goes BOOM ~^
« Reply #9 on: May 31, 2013, 09:15:39 PM »
 That's really cool, very nicely done too. Better slam a Red Bull or two before you launch this one!!! y1
Offline Peter Grabenstein
« Reply #10 on: May 31, 2013, 10:07:15 PM »
Hi Kreth
I used a hairdryer to get the nylon covering tight as a drum back
in 75 on my "Blitzkrieg" Combat models with MVVS D7 Dieselpower.
Dont get to close, just heat up the spot slowly.
Afterall check the wing for straight trailingedge.
A heatgun would be an overkill  temperature wise.
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
