  • July 18, 2025, 07:02:28 PM
Author Topic: Just anothor boring old Cessna  (Read 5679 times)
« on: June 03, 2011, 10:56:32 AM »
I picked up a Fox 40 from a Craigslist ad yesterday.  $8.  It has good compression, and now that I've put the piston back in the right way around, it should run pretty good.  So I'm thinking that I'll build a plane for it -- because even if it's not the World's Best Stunt Engine, it's kinda hard to beat $8.
I'd mentioned the Cessna Agwagon article in the October 1979 FM in another thread, and John Stiles wanted a picture -- so here it is.  I'm going to dig out my Impact article, and if the numbers on the Agwagon differ too much I'll jigger it around until it matches that, while still looking "Agwagon-ish".
Re: Just anothor boring old Cessna
« Reply #1 on: June 03, 2011, 11:10:55 AM »
Yeah, buddy....that's what I'm talkin about right there....but lemme swap ya a decent engine for that old boat anchor! ;D
« Reply #2 on: June 03, 2011, 11:39:53 AM »
I bet it sounds ferocious with that exhaust stack bolted up. But I'd rather see you with a .46LA.  H^^ Steve
« Reply #3 on: June 03, 2011, 11:48:12 AM »
All things being equal, I'd like to see me with a 46 LA, too.  Or better, an electric setup.
But they cost more than $8.  I figure I can build the plane, fly it, and if it's too much trouble to make work good I can give it away (or see just how badly John wants that engine :)).
« Reply #4 on: June 03, 2011, 07:09:58 PM »
Take the Cessna Agwagon - look at the impact article and make the following changes.
Alter the wing - to use the IMpact wing,
Build a full depth built up Fuse as to Impact plan
Modify the Agwagon tailplane to an Impact stab Dimensions and chord.
Keep the existing canopy shape.
Fox 40 is good - Id change it out for the VF 40 on pipe - that should be all you need to change.
« Reply #5 on: June 03, 2011, 07:10:41 PM »
« Reply #6 on: June 03, 2011, 09:29:43 PM »
 Heh, heh, heh. ;D
 Cool project, please don't ruin it by going electric.
« Reply #7 on: June 03, 2011, 11:14:06 PM »
PJ, your input is noted.  I was thinking more along the lines of retaining the Impact airfoil, tail volume coefficient, and possibly the wing aspect ratio.  Profiles are in for me right now, 'cause I'm still "Sir Crashalot".  Once I get past that I'll start doing full fuselage planes, and work on my finishing skills.
« Reply #8 on: June 03, 2011, 11:32:32 PM »
It was just a joke Tim. Im sure you picked up on that - I was once Knighted as Sir Crashalot also.
« Reply #9 on: June 04, 2011, 12:04:16 AM »
I dunno about the recognizing a joke thing - I'm pretty boring.
« Reply #10 on: June 04, 2011, 12:39:30 AM »
OK ok,,, so joke telling isnt my forte'  So - on a serious note - Dan Rutherford has a Wimpact which is a profile Impact.
Perhaps you could converse with him on the design / plan?
« Reply #11 on: June 04, 2011, 09:54:23 AM »
boy, Not sure you could pry anything out of Dan, he doesnt like to talk to much,,
Oh wait, that was when he was taking a nap,, never mind,,
« Reply #12 on: June 04, 2011, 12:28:05 PM »
I bet you could get PSJ to send you a pdf of a 600 sq. in. WimpAct, or at least ImpAct. I'd like one myself!  #^ Steve
Offline Bill Heher
  • Fix-it
« Reply #13 on: June 04, 2011, 05:07:57 PM »
Quick and dirty - get a SIG Banshee kit and alter the fuse profile to Match the article, redo the tail feathers, move the wing   Fwd for balance and see how that Fox runs.
I've had the same 45 R/C as yours in a .60 size R/C plane, it pulled that plane with good power. It would swing an 11X5 no problem.
« Last Edit: January 05, 2012, 07:19:59 PM by Bill Heher »
Bill Heher
If it's broke Fix-it
Offline Shane Hughes
« Reply #14 on: January 05, 2012, 02:29:20 PM »
Tim, if that is the Agwagon I think it is, the wing appears to be almost an exact copy of a Twister wing, with deeper flaps to match the trailing edge planform of the Agwagon. Both have almost exactly the same span. I was thinking to use the plans and a Twister kit to put together an Agwagon of my own. Cheers!
« Reply #15 on: January 05, 2012, 02:35:18 PM »
Tim,
I'm coming down there on the 14th. I'm bringing you the plane and I can easily bring along a spare OS40LA I have hanging around. I also have a spare 46LA that you can have for less than $8.   ;D
« Reply #16 on: January 05, 2012, 03:19:14 PM »
Randy, I'll be in your debt.
Offline David M Johnson
« Reply #17 on: January 05, 2012, 03:59:47 PM »
Build the AgWagon just like it is and when you fly it make sure to have fuel with as much castor as possible. With the resulting smoke it should do really well in the scale class! Good looking plane do you have actual plans for the plane?
David Johnson
We're havin some fun now!!
« Reply #18 on: January 05, 2012, 04:15:13 PM »
I just have the plans in the magazine.  If I need 'em, I'll order 'em.
« Reply #19 on: January 05, 2012, 04:28:22 PM »
I'm still watching...... ;D
Offline dirty dan
« Reply #20 on: January 05, 2012, 07:09:09 PM »
Quit that! If I spend any time at all discussing the Wimpact or W500 you-know-who will be all over it and I will have to cut my throat in order to get out of the looping circular logic.
Until PJ posted above picture--Thanks! Not!--I was safe as one had to pull a search of SSW archives in order to find information on either model.
Dan
(Mark & PJ: Nudge-nudge, wink-wink...)
Dan Rutherford
« Reply #21 on: January 05, 2012, 07:22:10 PM »
Dan : Finding it was easy, I just googled " greastest model ever built " and that photo came up  y1
ChrisSarnowski
« Reply #22 on: January 05, 2012, 08:39:09 PM »
You could fit an electric motor inside that old Fox 40
« Reply #23 on: January 05, 2012, 08:40:04 PM »
Tim sent you a PM
David Johnson
Offline dirty dan
« Reply #24 on: January 06, 2012, 12:36:05 PM »
Now that really is funny! Especially when I have always made it exceedingly clear this is merely the greatest film-covered profile CL Stunt model powered by a piped 25FP (an aluminum pipe at that!) using a plastic clunk tank and flown on .012" "StayTwisted" lines.
You shoulda known...
Dan
Dan Rutherford
« Reply #25 on: January 06, 2012, 12:45:49 PM »
maybe someone who knows more relabeled the photo Dan,, or there could be a conpiracy,,
hey you could avoid the whole film thing, ship it to FLorida, theres a guy there now who is painting stunt planes,, and he has way more experience than me,,
 ;D y1
« Reply #26 on: January 06, 2012, 01:04:25 PM »
It's so nice to see a member of the CL pantheon being modest...
Offline dirty dan
« Reply #27 on: January 06, 2012, 01:23:20 PM »
 ;D y1
Mark,
Clearly there is a conspiracy here. Besides, above only applies to my Wimpact. The W500 is now the greatest blah-blah-blah plus having a stressed-skin fuselage using Spyderfoam as the core and packing 500 square inches instead of 450.
As to having either model painted, your services would clearly be preferred, even though as you note your experience is severely limited. Still, it must be stated that I am not a big fan of shooting color through the discarded undergarments of wimmen...
My best,
Dan
Dan Rutherford
« Reply #28 on: January 06, 2012, 01:42:59 PM »
Dan? Modest? Uh, wow.
« Reply #29 on: January 06, 2012, 02:43:46 PM »
My best,
Dan
Dan, so does that mean you prefer shooting color through discarded MENS undergarments, cause that's just disturbing,,  n1
« Reply #30 on: January 06, 2012, 02:59:13 PM »
Bit of advice.  Just because you got an engine for $8 doesn't mean you have to build a plane for it.  Best idea is to run it on the bench to see if you are happy with how it performs.
You could spend a lot of time and a lot of money building a plane for that engine, only to find out that another, more modern engine, would be much better for stunt.  Then, you have to juggle the motor mounts and a bunch of other issues to swap engines.
It's best to listen to the advice of others about engine choice, rather than using whatever is in the junk box.
F,.C.
« Reply #31 on: January 06, 2012, 05:53:57 PM »
I'm going to try as much out of curiosity as anything else.  It certainly looks like it should be a dynamite engine if I treat it more like an FP 20 than a Fox 35.  (I.e., go fast and use a flat prop).
There's a free plane on it's way to me; if the engine will go in that without major surgery I'm using it, otherwise I'm going to knock something together that's almost (but not quite) too ugly for combat, just to see how it all works.
