  • June 26, 2025, 01:13:27 AM
Author Topic: Acme fuel tanks  (Read 3719 times)
Offline Bill Morell
Acme fuel tanks
« on: April 04, 2007, 08:39:58 PM »
I am planning on using one of these tanks in my latest project. This one looks like a mail box and is made out of brass. Anyone else ever used one of these and had good results? I am putting it in a full bodied plane. Reason for the choice of this tank was the limited amount of room and where the feedline lines up with the engine.
Bill Morell
Vietnam 72-73
Re: Acme fuel tanks
« Reply #1 on: April 04, 2007, 08:45:25 PM »
Hi Bill,
I have an ACME 4 oz. brass wedge (looks like the Perfect #11 IIRC) that works just fine.  It "wrinkles" pretty easy, though.  I have it on a profile and the rubberbands will crease it a little.
Bill <><
Offline Bill Morell
Re: Acme fuel tanks
« Reply #2 on: April 04, 2007, 10:03:34 PM »
Thanks Bill. Wrinkling should not be a issue as there will be no rubber bands holding this one in. It sure has been one of those nights. Was trying to put the controls and tank in and ended up just having to turn off the lights. Nothing was turning out as planned. Time to fall back and punt.
Bill Morell
Vietnam 72-73
Offline Garf
    • Hangar Flying
Re: Acme fuel tanks
« Reply #3 on: April 04, 2007, 10:23:45 PM »
Both of my Trickster Barnstormers use the Acme tanks. They work pretty well.
Offline Russell Shaffer
Re: Acme fuel tanks
« Reply #4 on: April 04, 2007, 10:59:30 PM »
Good point, Bill, about falling back.  I've come to the conclusion that when things start going wrong or something is complicated or just looks hard, if I give it a day or two very often the problem becomes much easier or there is a better way to do the job.  Works for model airplanes, household problems, and even stuff at work if there is time to wait a day or so if necessary.  It's when "it absolutely has to be done right now"  that stuff often happens.
Russell Shaffer
Klamath Falls, Oregon
Re: Acme fuel tanks
« Reply #5 on: April 05, 2007, 10:37:09 AM »
Mine leaked.  I eventually learned that fuel attacks brass, but only after several decades of trouble with brass tubing.
Offline Bob Zambelli
Re: Acme fuel tanks
« Reply #6 on: April 05, 2007, 11:03:50 AM »
If anyone is interested, the last time I visited the Brodak Hobby Shop, I saw a rather large assortment of brass tanks. I think they were the ones shaped like little mailboxes.
You can probably contact Patty for more info.
Re: Acme fuel tanks
« Reply #7 on: April 05, 2007, 11:09:35 AM »
I have used one in my Taurus with a Fox 59, and it worked just fine. I did rework it to make it a uniflow. The tank was marked U-6, but only holds about 5 oz.. Should work well for catching roadrunners!! LL~
Offline peabody
Re: Acme fuel tanks
« Reply #8 on: April 05, 2007, 04:51:24 PM »
The Acme Company is here in northern New Jersey......I've been there....
Interesting place....besides the tanks, they make HO gauge train widgets.....
It's like time stood still....rotary phones, yellow pages open....nary a compute in sight!
They don't seem to know about uniflow...
Offline Bill Gruby
Re: Acme fuel tanks
« Reply #9 on: April 05, 2007, 05:09:18 PM »
DANG;
  My inquisitive nature got to me again, I just had to go look after "Rich" posted. Take a look.
                            http://www.acmemodel.com/tanks.htm
  "Billy G"   CLP**
Bill Gruby
AMA 94433
MECA 5393-10
Re: Acme fuel tanks
« Reply #10 on: April 05, 2007, 05:12:38 PM »
Darn it!  They don't carry the "BIG" wedges anymore.........
Bill <><
Offline Ward Van Duzer
Re: Acme fuel tanks
« Reply #11 on: April 06, 2007, 08:56:39 AM »
Although the "U" shaped tank looks good, I too have heard that the brass will crack. And the fuel will attack the brass creating green goop inside the tank. Pretty much all the same reasons we switched from brass tubing, to copper in our current tanks...
Offline Bill Morell
Re: Acme fuel tanks
« Reply #12 on: April 12, 2007, 02:47:03 PM »
Is there anything that can be used to flush out the tank after a flying session to stop the green crud from developing?
Bill Morell
Vietnam 72-73
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Acme fuel tanks
« Reply #13 on: April 13, 2007, 08:34:04 AM »
What I love about them is that a little polishing and clear sprayed over them they look really cool on a profile plane. I glue them to a plywood base plate and use screws throu that to hold them on. As for flushing acetone and paint thinner is what I have used. As for how long they last I don't know I crash alot so the get holes and break befor too long.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline dennis lipsett
Re: Acme fuel tanks
« Reply #14 on: April 15, 2007, 07:54:53 PM »
I just took one apart that I'd used for 5 years. I had flushed this tank at the end of every season. That really didn't matter as the inside was really green and it required a toothbrush and cotton swabs to get most of it out. Strange though I never had any problems with the tank on the plane and wouldnt have known about the inside until I punctured it  last week. I have another one on a TCI Walker/ Firecat with a fox 35ABC that has been flawless in operation for a lot of years. Believe it or not the tank is silicon glued directly to the fuselage and there are no run problem...ever!
Dennis
Offline Phil Coopy
Re: Acme fuel tanks
« Reply #15 on: April 15, 2007, 10:20:52 PM »
Hope you get better results than Wiley Coyote did....... LL~
Phil
Offline Wayne J. Buran
Re: Acme fuel tanks
« Reply #16 on: April 16, 2007, 04:18:30 AM »
I stock several sizes of Acme tanks. Some of the Navy Carrier guys find them usefull because of the shape and they are good for replumbing. The Acme tanks are no differant than any others you just have to take care of them.
Wayne Buran
Northcoast Hobby
Wayne Buran
Medina, Ohio
AMA 14986 CD
USAF Veteran 35 TAC GP/ 6236 CSG, DonMuang RTAFB, Bangkok, Thailand 65-66 North Coast Controliners   "A fine is a tax for doing wrong. A tax is a fine for doing well!
Offline jjramjett
  • ACE
Re: Acme fuel tanks
« Reply #17 on: April 16, 2007, 06:24:20 AM »
Most of us old farts started life with Darwin tanks, made the same way from the same material, as well as Thomas and Acme and other brands. Brass tanks are good, they take a little  care, like dont put it up with fuel still left in the tank. I never had a cracking problem, probably because I broke them before they broke themselves.  I have used Acme from time to time because of space limitations and had no problems in fuel draw, just some green junk.  No reason to be afraid of them.
Jon Ramsden
