  • June 27, 2025, 10:46:58 PM
Author Topic: Update on Frisky Pete test build  (Read 1055 times)
Offline Mike Griffin
« on: September 25, 2018, 12:30:36 PM »
The test build for the Frisky Pete is progressing.  Everything is going together as it should but I have run into a slight delay in building the fuselage due to some corrections that needed to be made.  I am waiting on the parts to continue the build.  Hopefully I will have a complete build done in the near future.  Just want to make sure everything is correct before releasing the kit.  Thank you for your patience.
Re: Update on Frisky Pete test build
« Reply #1 on: September 25, 2018, 08:10:37 PM »
Do you need a holding payment? ???
« Reply #2 on: September 26, 2018, 07:01:54 AM »
No Doc, that is not necessary.  I will let you know when they are ready to ship and you can send the money then.  Thank you for asking.
Offline Joseph Patterson
  • AMA member- Supporter
« Reply #3 on: September 26, 2018, 10:47:08 AM »
 I'm still in too, Mike!
          Doug
« Reply #4 on: September 26, 2018, 03:56:44 PM »
I have you down for one Doug.  Thank you
« Reply #5 on: September 27, 2018, 10:20:36 AM »
Just waiting on some parts to arrive to continue the fuselage test build.
