  • July 26, 2025, 12:21:33 PM
Author Topic: PROFILE LANDING GEAR  (Read 1191 times)
Offline petermick
« on: May 24, 2012, 09:06:29 PM »
Who sells carbon or alumunum landing gear for a profile SigTwister swinging an 11 inch prop?
Peter Mick AMA 9581
Re: PROFILE LANDING GEAR
« Reply #1 on: May 24, 2012, 09:30:07 PM »
 Sig does. Sig "Fazer" aluminum gear (SIGRPBA268) works perfectly for most any .25 to .40 sized profile model. I keep a few sets in "inventory" all the time. y1
« Reply #2 on: May 24, 2012, 09:31:50 PM »
SIG's Fazer LG is the bargain deal; maybe available at your LHS. Brodak sells the same piece under their own label, I believe. If you look in the vendor's forums below, Steve Wilk has two grades of CF LG struts. They are the same except for the spendy one has carbon cloth on the outsides, to prevent splitting. Should work for 11" prop, but might get close if you don't plan ahead. Perhaps somebody has used them on a Twister and will chime in?  H^^ Steve
Offline Allan Perret
  • Proverbs
« Reply #3 on: May 25, 2012, 05:14:10 AM »
Peter Mick AMA 9581
Randy Smith (Aero Products) had his new c/f profile gear at the Atlanta contest last week.
Allan Perret
AMA 302406
Slidell, Louisiana
