  • July 18, 2025, 04:14:02 AM
Author Topic: Johnson Stunt Supreme Displacement?  (Read 1260 times)
« on: July 05, 2014, 02:27:21 PM »
Hi All,
What is the actual displacement of the Stunt Supreme?  I have heard they are a little less than ".35".  If so, what is it, actually?
Thanks!
BIG Bear
RNMM/AMM
Offline steve bittner
Re: Johnson Stunt Supreme Displacement?
« Reply #1 on: July 05, 2014, 03:26:56 PM »
It is a 35 bore .770 stroke .750 compression 6.5-1 weight 7.6 oz
« Reply #2 on: July 05, 2014, 04:27:25 PM »
Thanks, Steve.  I had heard of a .32 or .33 that was said to be an SS and I knew some of the guys here would know.
Thanks!
BIG Bear
RNMM/AMM
« Reply #3 on: July 05, 2014, 04:35:35 PM »
WHEW!  That's a relief!  Now you can put it in a real big plane.
F.C.
« Reply #4 on: July 05, 2014, 06:59:44 PM »
Johnson had an engine stamped 32 on the side, then early stunt engine with a plain single S stamped on it.  Im using a Johnson 35 in a 59 inch wing span Hi Johnson stuka. It pulls the plane very well about 80/85 thru all the manuvers. If you use a muffler it may kill the power though.
Offline Garf
    • Hangar Flying
« Reply #5 on: July 06, 2014, 11:51:29 AM »
Try this:
