Two years ago, when I went to Clovis last, I flew my model in the Seattle area, then Clovis, and then out on that dry lake near "Cinder Cone" on Hwy. 395. I thought it was ok in Seattle and Clovis, but when I got to that dry lake, I found that my "bottoms" were much better. I came home and narrowed the handle spacing one hole, meaning 1 hole on each end, or 1/4", and liked it better.
So, yes, handle spacing is something that one might change if temps change much, or if you've gone to a different altitude. I'm not sure about humidity, but suspect it would also be a factor?
