  • July 11, 2025, 11:49:08 AM
Author Topic: My Humbug  (Read 4070 times)
My Humbug
« on: March 07, 2009, 11:55:24 AM »
Here it is finally in its stupendous finish.  Was trying to keep it light.  Base covering is SLC from the Corehouse covered with 00 Silkspan put down with water base acrylic poly paint.  The numbers are Monokote and main finish is Brodak clear.  Weight is 2 pounds 4.4 ounces.  Power is an OS 25 FP with an Enya strap on muffler.  Yes it is the RSM Distribution version of the Humbug.  Have E-Mailed Eric on what I thought of the kit, so don't aske questions and I won't tell any lies.  It was a challenge.  I just hope it flies.  Last picture is the demented Poodle that got me thru this build.  DOC Holliday
Offline Leester
Re: My Humbug
« Reply #1 on: March 07, 2009, 12:00:44 PM »
Looks Great Doc !!! Also on the secound picture it looks like it passed the Cat Scan. Your Dog looks tired, you must have made her do all the sanding  LL~ LL~ LL~
« Last Edit: March 07, 2009, 12:25:28 PM by Leester »
Leester
ama 830538
Re: My Humbug
« Reply #2 on: March 07, 2009, 12:05:41 PM »
Sandy is going to chew on your ankle.  It's a female.  DOC Holliday
Offline Leester
Re: My Humbug
« Reply #3 on: March 07, 2009, 12:25:02 PM »
oops I'll fix that.
Leester
ama 830538
Online Dennis Adamisin
Re: My Humbug
« Reply #4 on: March 07, 2009, 12:38:24 PM »
Nice job Doc!   8)  H^^  #^  ;D
Can't tell - does yours have a single wheel & tip skids?  Lately I have been wondering about building one with electric - I think the e-power would come close to mimicing what Wild Bill and Bob Baron had in mind with the original high RPM flat pitch set-up...
Re: My Humbug
« Reply #5 on: March 07, 2009, 12:57:35 PM »
We should know that, since you call your doggy "the Demented Poodle".  y1
Is the fuel tank inboard on the Humbug? Otherwise, I'm wondering why the "flat four" cowling. The 36 oz seems a bit porky for a .25, but the high A/R should carry it ok. You did the right thing with the clear dope finish, tho you might not like the fuel resistance level of it. I really can't see a reason to cover with plastic first, but maybe we'll talk about that in Tucson...  LL~ Steve
PS: I wanna see the Humb'er (and be) in Tucson REALLY SOON! It's snowing hard right now!  HB~> The drive might be pretty exciting....
Re: My Humbug
« Reply #6 on: March 07, 2009, 02:24:03 PM »
The Humbug looks great, Doc. That's another plane I've always wanted to build. Will you bring it to VSC so I can oogle it?
BTW, Mork called. He wants his suspenders back. LL~
Re: My Humbug
« Reply #7 on: March 07, 2009, 07:51:23 PM »
Dayadgummit, Doc...that is one fine masterpiece. I don't believe I ever saw one like that before....but it's about the coolest thing I ever saw y1 H^^
Re: My Humbug
« Reply #8 on: March 07, 2009, 07:55:02 PM »
doc,
Smile, the plane looks great. In the picture, you look like you just lost your last friend.   ;D
Offline Leo Mehl
Re: My Humbug
« Reply #9 on: March 08, 2009, 10:36:05 AM »
doc,
Looks real nice Doc and I also think you should smile more seeing the build is done.My kind of finish. Ilike see thru finishes. H^^ H^^ H^^
Offline Bill Heher
  • Fix-it
Re: My Humbug
« Reply #10 on: March 08, 2009, 10:46:31 AM »
I was wondering the same thing. I would think that if a person was going to use 2 layers, 1 SLC and 1 Silkspan- the Slikspan would go on 1st for strength with a couple coats of clear, then the SLC on top to fuelproof everything and keep the weight down. Or am I totaaly off the mark here?
Bill Heher
If it's broke Fix-it
Re: My Humbug
« Reply #11 on: March 08, 2009, 03:39:33 PM »
I did it the way someone told me it should go with the covering.  Takes less dope and give the  classic silkspan/dope finish.  I am smiling in them pictures.  The Humbug is mucho bigger than Primary Force and is 2 ounces lighter.  Difference is LA 25 on PF and FP 25 on the bug.  Probably make maiden flights in Tuscon town.  DOC Holliday.
PS:Only 5 more days before departure. jeh
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
Re: My Humbug
« Reply #12 on: March 08, 2009, 04:05:26 PM »
Very nice model and photos, John! Your dog looks like a sweetie.
The model is very interesting. Great job.
L.
"My grandfather invented Cliff's Notes. It all started back in 1912...Well, to make a
long story short..." -Stephen Wright
Online Matt Colan
Re: My Humbug
« Reply #13 on: March 08, 2009, 04:14:31 PM »
Looks good John.  It has a simple sort of elegance to it.
Online Paul Taylor
Re: My Humbug
« Reply #14 on: March 09, 2009, 02:54:53 PM »
I'll Take it!!!
Re: My Humbug
« Reply #15 on: March 09, 2009, 03:07:46 PM »
Doc,
If that's your smile, remind me not to irritate you.   ;D
Offline Shultzie
Re: My Humbug
« Reply #16 on: March 11, 2009, 01:26:56 PM »
Doc,
Hey Doc...
If that fantanstical' Hummmmbugga-bugger' turns as quickly as Bob Baron's....I would recommend a quick stop  bye your local Starbucks..and stock up on a LITTLE JIVA-JAZZ SAUCE before your first test hops to PUMP UP YER REFLEXES!!!! H^^
Don Shultz
Offline afml
Re: My Humbug
« Reply #17 on: March 11, 2009, 06:20:07 PM »
A nudder "Humbug".   #^
"Tight lines!"
Wes
Wes Eakin
Offline Clayton Berry
  • Grey haired kid to be wary of
Re: My Humbug
« Reply #18 on: March 11, 2009, 08:46:23 PM »
Hey Doc...
That is a good looking aeroplane.  I had some plans for one awhile back.  Don't know what version.  Hal Howard, if I recall.  Might just be a good place to mount one of them nearly new OS 35S units I've been hoarding.  A man is known by the length of his stabilizer, you know.  Even if it takes a couple of booms to keep it stiff.
Clayton - forever busy committing random acts of coolness
