  • June 21, 2025, 08:22:57 PM
Author Topic: Mowing  (Read 1829 times)
Offline Peter in Fairfax, VA
Mowing
« on: March 15, 2021, 01:19:19 PM »
About how long does it take to mow a circle for 70' lines, using a typical 21" gas powered mower that you push?
Asking for a friend...
Offline GERALD WIMMER
    • Auckland Free Flight Club
Re: Mowing
« Reply #1 on: March 15, 2021, 01:37:42 PM »
Hello It takes too long over 2 hours to mow a circle with a hand mower but depends on grass height.
 If you just cut a take off and landing strip from 70 down to 50ft and a centre circle around 30 minutes .
Our club has in the past got a group together with push mowers the night before a contest to bring it down to height when using a public park or school.
 If mowing a whole circle and pit area regularly you need a ride on mower/tractor and the bigger it is the faster it goes. Our Toro 28hp out front mower with 62inch deck takes about 40 minutes to do the lot but our 82 HP John Deere with 80inch mulcher can do it all in 20minutes.
Regards Gerald
Offline Doug Moisuk
Re: Mowing
« Reply #2 on: March 15, 2021, 02:18:05 PM »
If you have a buddy or two with mowers you can cut the time way down.
Doug Moisuk
MAAC 3360L
Re: Mowing
« Reply #3 on: March 15, 2021, 02:37:34 PM »
Yes it takes a good two hours to mow a 70 foot circle with a 21 in mower.  I've done it in the past when I wanted to fly.  This is with no breaks except for getting water in side of the body. H^^
Online Howard Rush
Re: Mowing
« Reply #4 on: March 15, 2021, 02:44:24 PM »
I used to mow the Arlington circle with a push mower. It makes one appreciate how big a stunt circle is.  I got a riding mower for Stonehedge, but buying fertilizer still gives me that appreciation.
Online Mike Hazel
Re: Mowing
« Reply #5 on: March 15, 2021, 04:11:06 PM »
This reminds me of how it was done at the Eugene airport field when the Eugene Propspinner club still had access there.
It was done kind of on an auto-pilot system.  At the middle of the circle was staked a large spool of nylon rope.  This became a tether for a standard size push type mower that had power to the wheels.  The mower had a special bridle fashioned onto it for the rope to attach to.   Once the mower was started up, the power to the wheels was engaged and you just let it go on its own.  It would slowly just unwind from the center working its way out to about 70 or 75 foot radius.  It was not real fast, but then again no one had to do the pushing!
Online Mike Hazel
Re: Mowing
« Reply #6 on: March 16, 2021, 09:22:38 AM »
A rider mower operating without a operator would really look funny!   This also brings to mind the old stories about Jim Walker and his radio control lawn mower.
Offline Frank Imbriaco
Re: Mowing
« Reply #7 on: March 16, 2021, 10:19:54 AM »
It takes me 20-25 minutes(depending on the heat) to  low cut a circle, 60' to a width of 70' and a path to lines and airplane using a 21" push mower. After that, I'm pretty much wiped out. As a consequence,  results at the handle aren't my best.
Every season I tell myself that this is stupid and no longer doable because I ain't  no Spring chicken. Maybe this year I'll call it quits and fly somewhere else. The circle I cut  is at  an R/C field that's beautiful , wide-open and turbulent free. The backup choice site is paved, but a real mix master. Good grief, Charlie Brown
Offline BillP
Re: Mowing
« Reply #8 on: March 16, 2021, 11:13:10 AM »
I used to mow a 10k+ sq ft lot with a 22" pusher and briggs engine in about 40 min.  Now I mow 40k+ sq ft with a rider in 45 min.
Bill P.
Re: Mowing
« Reply #9 on: March 16, 2021, 02:19:43 PM »
Just want to clarify that I only cut a 10'-11' wide area and a a path for the lines to rest in. The field is mowed once a week, but it's always too high for my tastes.
Offline John Rist
Re: Mowing
« Reply #10 on: March 16, 2021, 05:14:00 PM »
Had a friend that rigged a car wheel rim (no tire) on a stake in the middle of the circle.  Same thing as above, self propelled push mower tethered  to the wheel.  It was unwind till it hit the end and then rewind till it ran out of gas. With experience learned how much gas it took to mow the circle.   Of course you have to get the drum size correct to match the size of the mower. He would then  finish up the center by hand.
