Glenn,
Another thought.....I don't know what stage your model is at, but here is a technique that I use for
perfect flap centering, but it has to be done early in the building stage.
In this photo, I wanted to keep the flap centered while setting up the pushrods. The jig is holding
the flap horn centered, based on visual alignment with the center line that is drawn on the side of the
fuselage (the centerline is something one should always do).
But, if you look closely, you'll see the head of a straight pin that was pushed through the fuselage
side, right on the centerline, and right where the trailing edge of the flap will be after its installation.
Simply push the pin through the fuselage side until it seats, and then cut off the length of the pin
that is inside the fuselage.
If you are real persnickety, you can remove the pin head before finishing and painting, or you can
leave it there, and always have a reference point for centering the flaps. Depending on how much
you love to sand, the head of the pin may be sanded off during that process.
Cheers,
Warren Wagner
