  • June 27, 2025, 09:30:20 PM
Author Topic: Brian Eather props  (Read 2828 times)
Offline Jim Morris
Brian Eather props
« on: July 11, 2007, 07:45:54 AM »
Does anyone know how to get in touch with Brian Eather, I need a prop or two for the Stalker 66. I heard he had some involvement in the developement for a prop for this engine.          Thanks.
Re: Brian Eather props
« Reply #1 on: July 11, 2007, 08:43:47 AM »
Jim,
Might talk to Alan Resinger (he's in the PAMPA directory). He is running a 66 and has a lot of contact with Brian Eather.
Offline Bradley Walker
    • The Urban Rifleman
« Reply #2 on: July 11, 2007, 10:34:17 AM »
I call him about twice a month...
What are you looking for?
PM me and I will pass on the info.
-George Bernard Shaw
Offline PatRobinson
« Reply #3 on: July 11, 2007, 01:08:28 PM »
Hi Guys,
What size , pitch and type ( 2-blade, 3-blade) props does Brian sell and how do you go about ordering from him. Actually, It would also be nice if he was on the vendor forum.
Google did not show anything on his prop sales when I checked some time ago, so I pretty much forgot about his props till I saw this thread so I thought I would ask.
                                                              Pat Robinson
« Reply #4 on: July 11, 2007, 01:21:12 PM »
vicstunt.com
Offline Jim Morris
« Reply #5 on: July 11, 2007, 04:34:25 PM »
Thanks for the reply, I tried to e mail him some time ago but had no response. I believe he made a 3b 12.5x6 prop for the 66, but it might be a 12x6,not sure.I will try again to get in touch through e mail. Any help would be appreciated.
« Reply #6 on: July 11, 2007, 04:36:33 PM »
HE does.
He just sent me two 12" three blades made for the Stalker/ST 60.  They are beautiful.
Are you running the 66?
Offline Alan Resinger
« Reply #7 on: July 12, 2007, 05:36:09 AM »
Brian was in Europe for a bit so wasn't available.  The choice of prop for the 66 is a 12.5 X 5.25 3B.  Brian doesn't finish his props any longer due to some shoulder problems.  You can buy direct from him but the props will be as they come from the mold so you will need to remove the flashing and do the final sanding for pitch and balance.  The Stalker 66 that I'm running works really well with the aformentioned prop with just a little bit of undercamber on the blades.  I run 20% nitro ( Powermaster YS/Saito 20/20 ) with a couple of head shims.  My muffler is slightly different from the stock one and is just a bit quieter.  I run muffler pressure and metal uniflow tank.  Launch is at about 7800 rpm, and fuel consumption is about 4.75 oz.
Offline Jim Morris
« Reply #8 on: July 12, 2007, 07:48:14 AM »
Thanks Alan, and yes Brad I will be running the 66 on a new Avanti. It seems to run great on the bench. Should put out some torque because the head is about 1/4 in taller than the other Stalkers I have run.
