  • July 18, 2025, 09:40:30 AM
Author Topic: Teosawki finished and first flights  (Read 3202 times)
Offline pipemakermike
« on: September 18, 2014, 10:51:03 AM »
Well, it is finally finished and I flew it yesterday.  The CG came out spot on the centre of the spar and the dry weight was exactly 32oz.
It flew well and will be better when I have got is better trimmed.  I feel as though I am holding some down on when I am flying and the speed is a bit quick (4.5sec/lap) and a bit short of range 4.5 mins on the tank that prefiously gave me 6.5 mins when I had the same engine combination in my Mo-Best.  I made a new venturie and started off with a 7.4mm hole with a 4mm spraybar and this is too big I think. Next time out I will use a 7mm venturie and I will probably reduce the nitro from 8% to 5%.
I had 3 flights and learnt something each time.  It turns well in both directions and has a sufficiently sharp corner for the squares.
Mike Nelson
Re: Teosawki finished and first flights
« Reply #1 on: September 18, 2014, 10:56:25 AM »
Nice, I like it!
How did you do the LE?
« Reply #2 on: September 18, 2014, 11:35:01 AM »
The LE is hotwired foam  It was a strukggle to work out a way to achieve what I was aiming for but I now know how to do it.
I covered it in Christmas wrapping paper.
Mike Nelson
Online Paul Taylor
« Reply #3 on: September 18, 2014, 11:55:55 AM »
Looks great!
What muffler are using?
« Reply #4 on: September 18, 2014, 12:07:38 PM »
Hi Paul
The silencer is one I made.  There are drawing here:-
http://www.machineconcepts.co.uk/aeromodelling/st51/ST_51_tube_muffler.pdf
That drawing is for the ST 51 but if anyone is interested I have the drawings for the LA 46, the Eyna 45 and the ED Hunter
Mike Nelson
Offline Garf
    • Hangar Flying
« Reply #5 on: September 18, 2014, 01:46:48 PM »
I would be interested in a set of leading edges.
Online Paul Taylor
« Reply #6 on: September 18, 2014, 03:14:49 PM »
Hi Paul
Your a handy kind of guy.
My next question was going to be where do I buy one. 👍
Offline WLGeorge
« Reply #7 on: September 18, 2014, 03:39:01 PM »
Good looking airplane.  Love the muffler.  What does it weigh?
« Reply #8 on: September 18, 2014, 04:23:10 PM »
For all that it looks like a slow combat plane that wandered into a stunt contest by mistake, I think you could come contest with us and get a few appearance points -- you did a very good job making that design look good.
Offline ray copeland
« Reply #9 on: September 18, 2014, 07:57:39 PM »
Great project!! One of my all time favorites!! Looks great, hope it flies well for you!!!
Offline Guy B Jr
« Reply #10 on: September 19, 2014, 03:45:49 PM »
Mike, great job.
You really did keep it light at 32 oz dry. If you look at Wayne Foster's list of specifications for the Teo, he shows Clayton's at 24 oz, without engine, muffler and tank. I just weighed a LA46 w/front NVA at 8 7/8 oz plus 2 3/4 oz muffler plus 1 5/8 oz for tank which equals 13 1/4 oz. Add this to the 24 oz bare plane and his total would come up to 37 1/4 oz dry.
Guy Blankinship
Offline Will Davis
« Reply #11 on: September 19, 2014, 07:37:36 PM »
Mine weight from 36 to 39ounces with standard la46 with  big rc muffler , mike did a great job on the weight , there's some weight to save with wood selection, muffler , covering , etc, I believe the Fascal has excessive weight over some lighter  coverings ,
Will Davis
"Carolina Gang"
« Reply #12 on: September 20, 2014, 02:44:36 AM »
My silencer weighs 1.2oz (33gm) compared to the 3oz weight of the standard silencer(both including mtg bolts).  I covered the model with lightweight tissue (actually some that my wife had wrapped around some flowers hence the colour). The leading edge is covered with light Christmas wrapping paper.  The ply fusalage sides were 1/16" ply rather than 3/32" as I have failed to find a source of 3/32"  The spars were cedar rather than spruce as that was what I had in stock (the cedar was cut from shelves salvaged from Cambridge University Chemistry department and were at least 100 years old and very dry).  The stabiliser was built-up.  I chose light wood for all parts.  I didn't make a special effort to save weight but I am generally a light builder.
I have now made a couple of new venturies one Ø7.0mm and one Ø6.5mm and will try them next time out.  I am hoping that this will give me control of the engine which currently is too fast and using too much fuel.
« Last Edit: September 20, 2014, 03:12:16 AM by pipemakermike »
Mike Nelson
« Reply #13 on: September 20, 2014, 06:55:10 AM »
Mike,
Are you that gentleman that's doing all the design renderings, detail drawings for a locomotive?
If so, could you please provide a link to that restoration, I had it once and cannot find it.
If you are the guy, the skills you have to provide for and compliment that project is amazing.
Charles
« Reply #14 on: September 20, 2014, 07:24:54 AM »
Hi Charles
Yes, that is me. I have been working on this since the beginning of 2011 and we are now well on with the build and the design.  I am currently working on the front pony truck and it is proving quite demanding.  I guess that we are well over half way thrugh the build and more than three quarters through the design.  The aim is to have it running by the end of 2015 (although that is probably the earliest).
Here is a link to my blog of the work.  I try to update it at least every couple of weeks and more often if I have achieved more.
http://www.machineconcepts.co.uk/baldwin242/baldwin.htm
and a picture of the blast stand which is the last finished component.
Mike Nelson
