General control line discussion => Open Forum => Topic started by: Paul Taylor on March 26, 2012, 07:40:34 PM
Title: It was about time!!!!
Post by: Paul Taylor on March 26, 2012, 07:40:34 PM
March and April are the two hardest months to find a weekend when the wind is not blowing or what I call gusty.
This afternoon after work it was as good as it gets this time of year. I am not sure why but the wind direction always blows in a direction where you are looking into the sun when stunting.  HB~>
Anyway I change out my LA 46 on my Tutor II with my new ebay LA 46 with a Randy Smith NVA. I think this engine is going to be a keeper. I did want to try a 12.25x3.75 APC prop also.
First flight was kind of soft on the lines running @ around 9100.
Second flight was launched at 9700. Half way into the flight I started to hear a rattling nose and then the engine started to sag and then quit. I called my Tech support guy and he explained what happened.
I went back to my old prop, 11x4 APC and got in two patterens. I was a little rusty but it felt good to burn some fuel.
Things I learned:
* Don't load up a brand new engine with too much prop. And look at what size plane you are asking the engine to haul. Size does matter. LL~
Something I'm not to sure about.
* I am using a lot less fuel. And I mean a lot less. I was using about 4.5 oz with my other LA 46, this one is using about 3 oz. Both have FP 40 venturi's. The only difference is one had a stock OS front NVA the new engine has the Randy Smith NVA. I like it. ;)
Title: Re: It was about time!!!!
Post by: Jeff Traxler on March 26, 2012, 08:25:32 PM
Hi Paul,If the new NVA has a larger diameter than the stock OS NVA it will let in less air and burn less fuel.Jeff
Post by: Paul Taylor on March 26, 2012, 08:49:43 PM
Hey Jeff,
I did have to drill out for the NVA.
Make sense.
Post by: ray copeland on March 26, 2012, 08:53:23 PM
Paul, all i gotta say is, if your only burnin 3 oz. of fuel for a pattern on a la46,  something ain't right!!   n~
Post by: john e. holliday on March 27, 2012, 08:28:07 AM
Its choked down too much.
Post by: Paul Taylor on March 27, 2012, 08:29:45 AM
Well I think I got a 5oz tank on this plane and it was about 1/2 full. I will try and get a good measurement next time out. But I know before I would fill it so that the fuel was just up past the back corner of the tank. Last flight was just a tad past 1/2 way on the tank and I still flew a bunch of laps after the pattern.
Still trying to get the engine broken in, but once I do I will get the numbers on the fuel. More to follow.......
Post by: Bill Little on March 27, 2012, 08:02:24 PM
HI Rootbeard,
With that size airplane and that size prop (12 1/4 X 3 3/4) you might need a bigger venturi.  It will probably work great on a smaller size model like the Vector or a Classic model.
BIG Bear
RNMM/AMM
