  • July 16, 2025, 03:10:30 AM
Author Topic: It arrived!  (Read 1607 times)
Offline Gary Dowler
It arrived!
« on: October 04, 2019, 05:03:50 PM »
My Stalker 46RE arrived !!  This will go in a Super Chipmunk which will be started next spring. After the regionals are out of the way.
The plan is to replace most or all of the wood, and then built according to Fitzgerald's suggested modifications.  Should be fun.
Gary
Offline Peter in Fairfax, VA
Re: It arrived!
« Reply #1 on: October 04, 2019, 05:29:16 PM »
Enjoy your building.  Plane to bench run the motor?
Re: It arrived!
« Reply #2 on: October 04, 2019, 05:43:17 PM »
So you're going to throw away the kit and just use the plans, wings and hardware?
This is why I scratch build -- I'm just too thrifty, I guess.
Offline Gary Dowler
Re: It arrived!
« Reply #3 on: October 04, 2019, 05:56:32 PM »
I guess that ultimately it will depend on the wood in the box. If it's decently light and cut out right, then I have no real objection to using it. Just not holding my breath on that.
But if I do just use it as a template set, then I could resell the kit later if I wanted. Recover some of the cost.
Will see how it all goes next year.
Gary
Offline Gary Dowler
Re: It arrived!
« Reply #4 on: October 04, 2019, 05:57:47 PM »
At some point, I would assume so.  I'll have to ask Ruslan what the reccomended break in procedure is on it, as there was no info with it.
Gary
Re: It arrived!
« Reply #5 on: October 04, 2019, 08:08:21 PM »
Offline kevin king
Re: It arrived!
« Reply #6 on: November 02, 2019, 10:32:33 PM »
Nice plane Gary H^^. What were Dave's suggested modifications on the Chipmunk?
Offline Gary Dowler
Re: It arrived!
« Reply #7 on: November 03, 2019, 04:16:51 PM »
They were quite numerous.  There is a thread on here regarding the subject.  It will add significant work, but should make a superior result.
Gary
Re: It arrived!
« Reply #8 on: November 04, 2019, 11:58:28 AM »
Ah! Pete Peterson's Chimpunk (sic).   y1 Steve
