General control line discussion => Open Forum => Topic started by: Matt Colan on August 09, 2011, 02:40:16 PM
Title: It's always the good airplanes that this happens to :(
Post by: Matt Colan on August 09, 2011, 02:40:16 PM
Today I was flying the Trivial Pursuit, and I had a fantastic motor run going, along with a pretty good flight.  I was doing the triangles and got one done, and it was a good triangle.  I started the 2nd one and after the 2nd corner, the upline broke and proceeded to do very tight outside loops.
I managed to maneuver it (I think whatever I did helped) to get it to pancake inverted. I ran back until the top of the loop, stopped, then on it's way back down whipped it again.  After 3 outside loops it hit rudder first.
At first I thought I did no damage except break a very good prop.  But when I walked to it, I saw the rudder was smashed.  There were a couple dents in the nose and that was it. Very fixable!
Tonight, I'm going to build a new rudder while grandpa gets the controls unjammed.  It should fly again in a week or so, depending on how the humidity is to spray the paint back on it.
This will be an easier repair than the Oriental Plus when it crashed last year.
Title: Re: It's always the good airplanes that this happens to :(
Post by: David M Johnson on August 09, 2011, 02:42:12 PM
Tough one I feel your pain.
David
Post by: Peter Nevai on August 09, 2011, 02:46:44 PM
Matt,
It is painful,most of us have been there quite often. I would suggest to give the plane a very thorough inspection. Every nub, bolt, nook and cranny. I had a pathfinder LE that has a similar event except mine was a rather hard inverted landing that tumbled the plane a couple times. Everything seemed fine except for the rudder which snapped off and I glued that back on at the field. The very next flight in the middle of the overhead 8. The wing folded completely in half mid air and that's all she wrote.
Better Safe than sorry.
Post by: Bill Hummel on August 09, 2011, 02:48:55 PM
Hey, Matt, no big!  Wondering:  where did the line break?  How old/how many flights on those lines?  Thanks...
Post by: Matt Colan on August 09, 2011, 02:56:26 PM
Matt,
Peter,
I did an inspection and the sheeting did also crack, so since we have to open up the pipe tunnel anyway, we're going to brace up the inside some more.
Post by: Matt Colan on August 09, 2011, 02:59:08 PM
Hi Bill,
The line broke at the handle.  The lines are perfectly fine.  There was about 50ish flights on the airplane, which almost has me wondering why these handle cables broke, and not the ones that are in my Oriental Plus.  It's the same Windy Handle design, and those cables have about 100 flights on them.  I should make a close inspection of those cables to make sure they are ok.
Post by: Ron Merrill on August 09, 2011, 03:04:23 PM
Hey Matt, a hard point handle may be the answer.IMHO, H^^ Ron.
Post by: Matt Colan on August 09, 2011, 03:06:22 PM
Or a Ted Fancher handle...
Post by: ChrisSarnowski on August 09, 2011, 03:07:32 PM
Hey Matt,
Sorry to hear about the crash. Good luck with the repairs!!!
-Chris
Post by: Matt Colan on August 09, 2011, 03:11:52 PM
Hey Matt,
-Chris
Thanks Chris,
If all goes according to plan, you'll still see it in Lee.
This means I NEED to get my Oriental Plus in better trim!
Post by: Wynn Robins on August 09, 2011, 04:37:35 PM
sounds like you need to bite the head off a herring to break the bad juju with this one.....man that sucks!!!!!
Post by: Larry Cunningham on August 09, 2011, 07:01:14 PM
..if it had been a REALLY great stunter, it would have shattered into a thousand pieces.  :P  If it had been covered with polyspan or silk or maybe (?? uncommon on a great stunter) moneykote, the covering would serve as a handy carrying bag for most of the pieces. Otherwise, they would flutter and blow away, littering the flight circle and grounds. Some spectators would pick up souvenir balsa pieces.
Your excellent engine (after extraction) would sport a bent crankshaft, a cracked case, or both.
That lovely $75 3-bladed carbon fiber prop, along with the specially anodized $50 aluminum spinner, would be completely broken, smashed, dented and scraped.
There would be loose pieces floating around in what remained of the fuselage, just waiting to jam the control system. (Of course, you wouldn't be able to tell if the ball joints had failed to cause the crash or were simply ripped apart by the impact.)
Your custom fuel tank would be dented, holed and permanently ruined. Something would be loose and rattling around inside the carbon fiber pipe.
Your $100+ carbon fiber wheelpants, aluminum gear, et al would be ripped from the fuselage - bent, cracked and mashed. One of your wheels would disappear into the pocket of a spectator, another "souvenir"..
Like everything else, your heart would be broken.
L.
"Fear nothing, for every renewed effort raises all former failures into lessons, all sins into experiences." -Katherine Tingley
Post by: john e. holliday on August 09, 2011, 07:44:39 PM
Sounds like this plane needs the witch doctor to take the hex off the plane.   Are you going to one or two ready for the team trials?   As someone stated get a hard point handle and try it.    H^^
Post by: Matt Colan on August 09, 2011, 09:03:21 PM
So I built a new rudder tonight, and even got it tissued!  The controlss are jammed and we've yet to cut the pipe tunnel open to unjam it.
We inspected the plane and the landing gear is cracked, and some of the sheeting cracked in the wing.
Post by: Tim Wescott on August 09, 2011, 10:13:00 PM
If you would stick to flying planes that you hate, you wouldn't crash the nice ones so often.
Post by: Gary_Marchand on August 10, 2011, 02:01:55 PM
Matt, I second what Peter Nevai said about checking the plane throughly. You must check the spar(s), LE and TE, especially if your sheeting is cracked. I pulled out of a outside square a little low and skidded a Roadrunner in upside down at Tucson. Only apparent damage was prop, canopy/turtledeck and a 1 inch shorter fin; just looked like road rash. After repair and 20 flights, the wing folded at the top of an inside square. I had apparently cracked a spar. If your sheeting is cracked you have stressed that wing big time. Look under the cracks and you may find interior damage.
Gary
Post by: Garf on August 10, 2011, 02:32:43 PM
I planted a profile once. I couldn't find any major damage. About 4 flights later, the outboard wing come off in flight, but it just kept flying.
Post by: Peter Nevai on August 10, 2011, 02:44:11 PM
L.
What he said, I know I was that spectator  VD~
Post by: Clayton Berry on August 10, 2011, 03:13:06 PM
I like giving mine a 'pull test' every flight.  A little wiggle on the handle to listen for that 'twang'.
Lost a Twister (sort of a Twister, anyway) on the second flight a few years ago.  Had used heat shrink tubing over the wrapping on the lines.  One broke anyway.  Thought I was being so clever.  Probably could have seen it getting old if'n I hadn't put that black stuff over it.
Ah, but the kid I gave the remains to didn't have to mop up much oil for the re-build.  2nd flight.  Did I mention that?  Not that I'm bitter or anything.
Pardon me for a moment - I needed to kick the cat.
Never even took a picture of that beast.  Transparent green film with cream colored trim.  My brother Dan and I finished it up when I went out to visit him for Christmas.  In the new PT Cruiser.  In the ice storm.  And the overly salted pot roast he and his lovely wife prepared one night.  And Uno and pistachios and old jokes.
Life is good.
Post by: Brett Buck on August 10, 2011, 03:14:29 PM
  Those are one and the same. I guess I must have missed seeing your handle at the NATs.  I would certainly recommended ditching any sort of cable handle immediately. Not only are they springy, they are also, as you found out, unreliable.
Post by: Steve Helmick on August 10, 2011, 03:42:07 PM
What Brett said. I can't believe anybody serious about flying any flavor of contest level stunt would use a cable handle. Try a hardpoint handle and  you won't go back.
I love my TED handles. However...at Regionals, I pulled the handle out for my profile and discovered that the lower attachment leg had pulled out about 3/16".  :-[  I could see that wasn't right, and I remembered that I felt a little "twang" on my last flight the previous weekend. I pushed it back where I thought it belonged and tightened all the screws up tighter. Tightened the pinch screws on the one for the SV-11, while I was at it. They're going to get CA'd into place, and I'd absolutely suggest that everybody do the same.   y1 Steve
Post by: Matt Colan on August 10, 2011, 04:06:35 PM
All I have is Windy handles and Brodak handles. The brodak handles I don't like at all unless I move the bar right up to my knuckles to get it the way I want it (the handle on my Ares is like that). I would like to try a Ted handle out but I don't have any, and don't know where to obtain one.
Brett, I'll show you my handle at the Team Trials, unless I go to setting different
Post by: Larry Fruits on August 10, 2011, 06:06:55 PM
 Matt:
   Give Carl Shoup a call. He makes kits for the "Ted" handle. He has two sizes depending on the size of your hand.
 970-250-8047      shoupentstatorrepair@prodigy.net
 Good luck making your repairs and at the team trials.
      Larry
Post by: Matt Colan on August 10, 2011, 06:24:14 PM
Matt:
      Larry
Thanks Larry!
I forgot to mention that the airplane is fully repaired, I now just need to paint the new rudder which I'll do tomorrow. It could fly again in 2 days if the humidity isn't too high. I'm going to paint the entire rudder red, and I'm thinking of making a new decal to put some sort of detail on the rudder.
Post by: PJ Rowland on August 10, 2011, 07:05:14 PM
Sorry to hear that Matt..
Everyone experiences a crash of some description with a big ship sooner or later.. Remember what I told you at the Nats about my bellcrank ! It jsut happens, what you need to do it take thie information everyone has given you and try not to make a similar mistake.
Some people will say models aren't " broken in " until they get some war wounds.. This is your first big stunter, so expect to have it brusied and battererd and keep flying it! Get 1000 flights on it. All the experiences you learn will help you in the future.
Hardpoint handles are VERY reliable.
So it broke at the Handle ? Did you see the line dangle free?
I DO NOT RECOMMEND THE FOLLOWING  Several years ago I had the line break at the handle.. I reacted fast enough to decide to grab the free handle with my other hand, and fly the remainder of the flight out like a Stunt Kite. Wrapped the line around my hand, and finger.. It wasnt until later someone told me how easily I could have severed my finger, its just not worth trying to save a Stunt ship risking any part of your person. Great story to retell..
Post by: Alan Buck on August 10, 2011, 07:06:16 PM
Hi Matt way did the controls lock up? was it from the crash or before the crash I know how you feel had a line braek on my staris it had 13 flights on it line broke 18'' from the handle in the vertical 8 still have the plane
Post by: Tim Wescott on August 10, 2011, 08:51:01 PM
I recently crashed a plane because a line got tangled in a clip at the handle.  I remember (a) trying to untangle it while flying, and (b) thinking afterward "what the heck was I doing, reaching into that cheese cutter when everything in creation is dancing around at 50mph?"
Post by: Matt Colan on August 10, 2011, 10:09:51 PM
The line flew away from the handle.  The first thing I saw was the black line clip I had on it fly away before I saw the plane do anything.
I wouldn't dare try something like that, nor do I think I'd have the reaction time to grab a broken line
The controls locked up because the bellcrank went through one of the braces we made to strengthen up the inside due to the wing cracking. I put another brace in after I cut that one away, but away from the bellcrank.
Post by: PJ Rowland on August 11, 2011, 12:04:12 AM
I managed to react ONLY becasue - I snapped the down line at the top of a vertical 8.. - Imagine being 1/2 way through the outside half of the top of the vertical 8 - then as hard as you can pulling FULL UP.. Poor plane didnt know what was going on!
Incidently..... I did recount this entire story in " Amazing model stories "
http://stunthanger.com/smf/index.php?topic=16970.0
Its a funny read..... about exactly what happened.
On the other side of the coin..
I've had 3 Fatal crashes due to this type of thing.
Thing to remember - If you can..
Walk toward it to slow the rate of turn down.....
Walk Away from it - to increase the turn radius... -
If your lucky and you time it right, you may be able to pancake it..( Like you did )  - What I've seen happen a few times, is people underestimate how quick the turn radius is - or simply dont do anything and freeze. Its never fun, no-one enjoys it.
Best advice I can ever give - is.. dont panic.... and try to remember :
Its going to crash no matter WHAT you do.. Anything you attempt is better than trying nothing at all. - If you minimise the damage - you might save it.
Post by: PJ Rowland on August 11, 2011, 12:14:38 AM
Matt:
Kaz Minato also does Hard point handels.
Post by: Derek Barry on August 11, 2011, 04:57:26 AM
Matt:
Yes he does and they rock! I use the Kaz cable handle with solids or the hard point with braids. I have never had a problem with either, I do check my lines and handle often...
Derek
Post by: Matt Colan on August 11, 2011, 08:38:15 AM
I checked my lines too, and when I went to make a slight handle adjustment, I noticed the cable was kinked, but it was the downline that was kinked. I shouldve stopped flying right there but I didn't. The flight before o felt something strange in the lines, like it was straining, once again I ignored it. I could have saved it all together by not flyin it.
And my grandfather told his friend mike, and he said, boy he even knows how to crash! Both of them said they would've froze and done nothing about it
Post by: john e. holliday on August 11, 2011, 10:16:31 AM
If you get the handle kit from Carl, think about the line clip making tool.  He has one as well as Lee Machine Shop.   H^^
Post by: Brett Buck on August 11, 2011, 11:43:06 AM
   Luck *AND* skill are both important!
Post by: Matt Colan on August 11, 2011, 11:45:27 AM
Definitely!! I got lucky that I was around 45 degrees when the cable broke. If I was closer to the ground, there would have been no hope in trying to save it.
Post by: Matt Colan on August 12, 2011, 04:13:47 PM
Well it's fixed, more or less. I still need to spray the clear on the new rudder and put a couple new decals on it. I put the motor back in, and ironed on a piece of red ultrakote where the dents were in the nose.
It's now got battle scars!  ;D
Post by: john e. holliday on August 13, 2011, 08:59:04 AM
This is going to wind up being your best flying plane.   Of course the pilot will have to fly better to make up for appearance. LL~ LL~Keep at ityoung man. H^^
Post by: Matt Colan on August 15, 2011, 07:04:08 PM
Here is the new rudder now awaiting to be mounted!
Post by: Matt Colan on August 16, 2011, 07:23:48 PM
Love the 50's era hot rod pin striping. Olde judges will give you 10 bonus points. H^^ y1
I like it too! And the color in the picture makes it look lighter.  I sprayed it directly over the base color and not putting any white over it, which made it much darker.  It resembles the color of a 78 Buick (we checked since we had some paint that matched).  WIth the urethane on it, it really POPS!
The rudder is back on the plane. We put 2 dowels in the rudder to give some place for the glue to stick to when it went back on!
Post by: Peter Nevai on August 16, 2011, 09:36:07 PM
I have learned to check the lines every flight, I run a rag over the lines during the walk to the handle. At the handle I take out any twists left in the lines from the last flight. If I detect a kink or even some curly Q's in either line, the flight is aborted, and the lines replaced. Following this regimen I have not lost another model due to line failure. I bet you'll do this from now on.
Post by: Matt Colan on August 16, 2011, 09:39:12 PM
I do that every flight, I don't check the handle. The scary thing is when we inspected the line was it wasn't frayed, or anything. It looked like somebody took a saw and sawed through it
Post by: Matt Colan on August 17, 2011, 09:07:06 AM
Here it is all set to go!
The new wire I have in my handle looks to be the same wire that is in the Brodak Bar handles.
I was also looking on Brodak's website and they sell what looks to be their own version of a Ted Fancher handle.  It's a hardpoint handle, but made of plastic.
http://www.brodak.com/shop_productdetail.php?ProductID=8462
I'm thinking I may want to get a hardpoinit handle for the Thundergazer so it's one less thing I have to worry about, and it's more reliable.
Post by: Doug Moon on August 17, 2011, 07:04:47 PM
Looks good.
The handle from brodak is steel through the center.  The handles are plastic on either side.  Its a very nice well designed product.
I think there is a large size and regular size.  I dont know the measurement difference though.
Post by: john e. holliday on August 18, 2011, 08:57:16 AM
Yes he shows a large and a small handle.  Doesn't give deminsions, but I would think along the lines of the old E-Z Just and Hot Rock. H^^
Post by: Ted Fancher on August 18, 2011, 11:56:09 AM
Matt,
If you'd like, I'd be happy to give Brett a used "Ted" handle for you to try out.   Might not match the color of your TP but...you can always put a paper bag over it when you're not using it.
As fast as you build/rebuild you could put together a lifetime supply of these things in about an hour!
Ted
p.s. Ask Brett what he thought about himself when he finally used one I gave him as a gift after carrying it around unused for a year or so!
Post by: Brett Buck on August 18, 2011, 02:48:40 PM
Matt,
   I could even supply the paper bag.
   And; after pooh-poohing the idea for about a year, I felt pretty silly after I finally tried it. A wasted year. Junk the cable handles ASAP, and get a hard-contact handle. More reliable and far better performance.
Post by: Chris McMillin on August 18, 2011, 04:08:37 PM
I couldn't believe the difference. It was "instant" input.
Chris...
Post by: Matt Colan on August 18, 2011, 05:42:19 PM
Matt,
Ted
Hi Ted,
I'll give it a shot. I'll have to try it on Friday when I get there...
I have yet to fly the TP since I repaired it, had heavy winds today and were busy the day before.  Hopefully in the next couple days since I got to get back into shape for a local contest.
Post by: Ted Fancher on August 18, 2011, 06:45:20 PM
Hi Ted,
Just finished digging through my cra....ooops, I mean...my stuff and found the one I used on the old purple TP that won the cup in 2000.  Wrecked it (the purple pond scum...not the handle) shortly thereafter and haven't used it (the handle, not the pond scum, obviously) since. (I still fly the original on my first hand-made Ted handle, by the way. works good and lasts a long time...since about 1994).
The adjustment movement was very stiff from sitting with the plywood compressed on the steel line attachment bars but I cleaned up a few edges and they can be adjusted by hand with a little work...which is as it should be.  The adjustable bars should be a snug fit so that you don't have to apply a lot of torque to the two bolts that lock them in place.
I'll get the handle to you through Brett and you can decide whether you have time to try it out or not.  You're welcome to use it as long as you like although I'd like to get it back at some time just for nostalgia's sake.  To make up for being an Indian giver I think I've got a handfull of kits that Carl gave me as a gift for turning over the design/sales gig to him.  I'll pack one of the kits up and if you think it's the way you want to go put it together and it's yours.
Ted
p.s. I'm going to send the handle with the screws loose and the bars all the way out so that you can adjust it to suit and then tighten it yourself.  Ask Brett to give you a heads up on tightening...it doesn't take Arnold what's-is-name on the wrench to seat them.  Firm but not 'red in the face' is the ticket.  You'll see the trick when you see the handle.
Post by: Matt Colan on August 19, 2011, 11:06:26 AM
Hi ted,
Thanks! I appreciate it
Post by: Doug Moon on August 19, 2011, 08:48:37 PM
I have several Ted handles and on one of my Bears it made it an instant Killer on the hunt.  It felt like I had my hand on the BC and it would go anywhere I wanted without any back talking.  It was insane how awesome it was.
But on the models I currently fly I cant get them to work right.  Oh and believe me it isnt from lack of trying. I have one on the paint stand right now and it will get trimmed out with a Ted handle to see if it is a better deal than the bar.
With the current ship on a Ted handle I cant hit my angles at all.
I would definitely try it out.  It may be just the thing you need to really take it to the next level.  But if for some reason it doesnt come around pretty quick dont fret just go back to what you know and get some solid practice in.  That contest is not nearly as attended as the nats and you will have plenty of time to try it out but at the same time dont spend all your time trying to retrim for the new item.
Post by: Matt Colan on August 20, 2011, 10:24:43 AM
Last year I went from a Brodak bar handle to Windy's type of handle after I was having trouble with the airplane in the wind.  The handle gave me power steering and the airplane became much easier to fly, and flew better!  After flying that plane for a couple months, I decided to fly my Ares with the bar handle, and I thought I was going to crash it.  After adding tail weight, and moving the bar in as close to my hands as possible, it made the difference so I could fly the plane without having to fly it all day just to get used to the amount of stick pressure again.  I don't fly bar handles at all anymore!
With everything that's been said on this thread, it seems like a Ted handle would be the next step up in performance with handles.
Post by: Ted Fancher on August 22, 2011, 06:10:15 PM
Hi Matt,
While I'm a big fan of my hard point handles and encourage you to try one out, I also have to agree with Doug about using what works best for you.  There are people who are proponents of a large variety of handles and, although the Ted handles have a substantial and successful following, getting the one that allows you to fly your airplane to your best advantage is a significant part of the winning equation.  I'm surprised at Doug's experience but, knowing his skills and dedication to finding that winning formula, respect his input.
By the way, after promising to send you a kit with Brett I almost panicked because I couldn't find the box of Handle kits that Carl provided back when he took over the production and sale of them.  Shareen convinced my to rummage around in my cluttered office and, although I didn't find the ones from Carl, I did come up with a small batch of the wood parts and one complete set of hardware.  Ergo, my promise is still good and you'll see both the kit and the purple Nats winning handle when Brett gets to Muncie.
Anxious to hear your evaluation of the handle and wishing you great luck at the Trials.
Ted
Post by: Matt Colan on August 22, 2011, 09:11:54 PM
Thanks Ted,
I have yet to fly the plane because of bad weather. Today was gorgeous but very windy. Tomorrow looks like I'll be able to fly it again, and I'll give a report on it. I expect it to fly like I had it when I had all the nose weight out of it, because the new rudder is a bit heavier than the old one.
Post by: Matt Colan on August 23, 2011, 03:34:53 PM
I flew the Trivial Pursuit today, and there's good news and bad news.
The good news: It still flies
The bad news: THE MOTOR RUN SUCKS!!!!!!!!!!!  The first flight I was flying at 5.8 and I could do most of the pattern with it. The 2nd flight, I cranked the needle in and it didn't sound right. I flew it, and was at 5.2 with a terrible sounding four-cycle. I ran out of fuel in the overheads and did get it to land (I didn't do any extra laps anywhere).  The motor now drinks gas like an old buick and I can only get about 5 1/2 minutes run time on a full tank of 6 ounces (It used to be 6:30 every time). Also, when I flip the prop, it doesn't spin free like it used to, it flips back to the compression and then stops, it doesn't keep bouncing back and forth.  I checked to see where I had the needle valve and it was over a full turn richer than where I had it last week when it went in.  And lastly, the noise. It doesn't sound like a huge ST 60 on a pipe like it did sound like.  It just sounds....off.
I probably bent something when it crashed because it stopped at TDC and my grandfather said he had an awful hard time getting it to get it turn over again.
Now I HAVE to get that Oriental Plus trimmed out to fly decent, and I'm starting off by shortening the lines a foot, then going from there.
Post by: EddyR on August 23, 2011, 06:32:16 PM
Matt    I dought you hurt your motor with a upside down pancake landing on grass. Pull the motor and tank, needle valve and spray bar and check them all very caefull. Then remove the head and backplate and check the motor. The motor should turn over smooth except at the pinch at the top of the stroke. Run the motor on a test stand and let us know what it does. Those type of landings many times damage the tank.
Post by: Matt Colan on August 23, 2011, 07:20:22 PM
We did that. I'm going to bring it to the team trials and have Richard Oliver look at it and see if he can figure anything out
Post by: Randy Powell on August 23, 2011, 09:09:27 PM
Sounds like crunched bearings to me. I had my RO-Jett 65 swallow a wrist pin retainer. Needed a new cylinder, piston and rod. It ran like you are suggesting.
Post by: Matt Colan on August 24, 2011, 07:19:21 AM
If that's the case, I could get those parts from RO and replace them Over here, but I still would want him to look at the motor to make sure that would be the case
Post by: Randy Powell on August 24, 2011, 09:26:26 AM
Absolutely.
Post by: Bruce Perry on August 24, 2011, 05:10:52 PM
Ted,
Yer a classy guy!  Mind you I already knew that.
B
