  • June 22, 2025, 04:46:30 PM
Author Topic: ISO Super Tigre 35 parts  (Read 3114 times)
Offline Jim Nohsey
« on: December 27, 2016, 05:40:46 PM »
Looking for a connecting rod for a super tiger 35. Does anybody know where I might be able to find one.
Jim Nohsey
Online Motorman
Re: ISO Super Tigre 35 parts
« Reply #1 on: December 27, 2016, 08:54:04 PM »
Do you have the old one, they can be re-bushed.
Offline Jim Nohsey
« Reply #2 on: December 28, 2016, 02:21:25 AM »
Yes I have the old one but it is broken
Jim Nohsey
Online Motorman
« Reply #3 on: December 28, 2016, 10:02:12 AM »
If something happened to break the rod, I'd look for cracks in the corners of the crankshaft intake window.
« Reply #4 on: December 28, 2016, 03:47:34 PM »
Which ST .35 series? The bushing .35C series, or G.21 series? I ran the snot out of two .35C's with zero failures.
FWIW, it was fairly common to replace OS .35S rods with ST .35 rods (OS rods weren't bushed and wore quickly). Some aftermarket rods have been made in small batches for the OS .35S, so it seems like they should also retrofit into a ST .35....or at least, some ST .35's. I'd ask Randy Smith, and Leonard Neuman (Stuka Stunt Works). Brian Gardner in Australia might also be able to help.  D>K Steve
Offline Jim Nohsey
« Reply #5 on: December 28, 2016, 04:22:04 PM »
It is the 35c series.
The engine was setting on my work bench with a prop on it. It was gumed up and I was going to free it up sometime. One of the guys that I used to fly with got to messing with it and he was trying to free it up. I told him to leave it alone, a few days later i got  it out and was going to free it up when I notice that it prop would move some back and forth. I removed the back plate and the connecting rod was broke where it conected to the crank. I just put it away. that has been several yrs back.
Jim Nohsey
Offline Jim Nohsey
« Reply #6 on: December 28, 2016, 04:24:09 PM »
Thanks Steve I will check with them.
Jim Nohsey
Online Motorman
« Reply #7 on: December 28, 2016, 06:22:53 PM »
Sounds like your friend free'd up half the engine anyway. If it's the C35 don't worry about the crank window.
Offline Rick Bollinger
  • AMA 931589
« Reply #8 on: December 29, 2016, 12:42:54 PM »
Jim check your PM's
Rick Bollinger
AMA 931589
Offline Jim Nohsey
« Reply #9 on: December 29, 2016, 12:56:29 PM »
ok
Jim Nohsey
Offline Chad Hill
« Reply #10 on: December 29, 2016, 09:57:51 PM »
The C35 and G21-35 use the same rod.
Online Motorman
« Reply #11 on: December 30, 2016, 09:25:08 AM »
Same rod in a couple supertigers, G21-46 is the same I think.
« Reply #12 on: December 30, 2016, 10:20:47 AM »
No the  29 and  35 uses the  same rod, the  40 and 46 uses  a longer  rod , except  for  very early  twin ring 46  will  use the  35 rod
Offline Jim Nohsey
« Reply #13 on: December 30, 2016, 11:10:54 AM »
Randy,do you have an rod that will work?
Jim Nohsey
Offline Jim Nohsey
« Reply #14 on: December 30, 2016, 11:11:39 AM »
Randy, do you have a rod that will work?
Jim Nohsey
Offline John Broughton
« Reply #15 on: January 04, 2017, 10:05:22 AM »
I have a Super Tigre connecting rod (new in pkg.) #02030108 which I believe is what your looking for.  Have you completely disassembled your motor and decided it's worth fixing?  If so, let me know where to send it via my e-mail "jbrghtncl@gmail.com"
« Reply #16 on: January 04, 2017, 07:12:56 PM »
NO I have  ST 40  46  rods, but  not  the  35/29  ones
Offline Chad Hill
« Reply #17 on: January 04, 2017, 10:57:18 PM »
Jim, I have seen the ST 35 connecting rod listed as part number C108, so I think John's rod will work for you. Best, Chad
