  • July 11, 2025, 10:20:05 PM
Author Topic: Is SIG Nitrate dope taughtning?  (Read 2953 times)
Offline Pat
« on: May 17, 2013, 04:21:44 PM »
Well guys, here is a question I never asked. Is Sig Nitrate dope taughtning or non-taughtning?
Pat
Re: Is SIG Nitrate dope taughtning?
« Reply #1 on: May 17, 2013, 05:13:59 PM »
Hi Pat,
All dope is tautening to some point.  Sig Nitrate is not as bad as Sig Supercoat clear which is high tautening.
BIG Bear
RNMM/AMM
« Reply #2 on: May 17, 2013, 07:56:08 PM »
Yeah, what Bill said. Sig nitrate will shrink enough to tighten the covering and remove the wrinkles.
Offline Pat
« Reply #3 on: May 20, 2013, 12:17:26 PM »
Bill,
I just used the supercoat to pull the wrinkles. Two coats of that will be followed by two or more coats of litecoat to stop the taughtning.
Pat
« Reply #4 on: May 21, 2013, 08:36:48 AM »
Dope never quits taughtning.
« Reply #5 on: May 21, 2013, 04:20:47 PM »
Bill,
Pat
Hi Pat,
If the covering is nice and tight, then it's time to go to the Litecoat for "filling".  Then your sanding sealer or primer before the blocking coat and colors.
BIG Bear
RNMM/AMM
Offline Mike Gretz
  • ACE
« Reply #6 on: May 22, 2013, 06:14:56 AM »
SIG NITRATE DOPE is non-taughtening type.  Just like LITE-COAT (non-taughtening butyrate).
The only full taughtening dope product we have is original SUPERCOAT CLEAR.
All SUPERCOAT colors are mixed in a non-taughtening butyrate (LITE-COAT) base.
Mike Gretz
SIG Mfg Co
Offline Michael Boucher
« Reply #7 on: June 09, 2013, 05:03:11 PM »
What is the difference between balsa filler coat and sanding sealer?  ???
AMA 59633
