  • June 15, 2025, 10:28:43 PM
Author Topic: Wheels?  (Read 5309 times)
Online Paul Taylor
Wheels?
« on: February 23, 2006, 09:27:48 AM »
So what is the best way to install wheels to insure they roll good. Mine seem a little gummy.
Do you ream the holes out?
Re: Wheels?
« Reply #1 on: February 23, 2006, 11:57:48 AM »
I would bush your wheels. I use an eyelet from Sig that fits the gear wire. The 1/8 gear wire I use works great with the 1/8 id brass eyelets from Sig.
Drill the wheel hub out to snugly fit the eyelet, put a little CA on the hub and push the eyelet in to stay. Make sure the bushing is square so the whell spins true. Now there is no problem with plastic-on-wire heat, breakdown of the plastic at the wire from fuel,oil,nitro, etc.
In direct opposition to your friend Rudderless in the post above, I put a little oil on my wheel's bushing as they will chatter on long landings.  A little cleaning will keep your wheels and gear wire clear of too much dirt.
Chris...
