Remember that the ST-style NVAs are 4mm OD (0.157"). They fit the Fox 35 crankcase but the Fox NVA is about 0.125" OD across the venturi—and so, reduces the venturi area much less.
Is the NVA that you are replacing constant diameter? If not, Randy Smith—and possibly others—supply an ST-style NVA that is necked down across the venturi to retain the stock venturi area.
