Randy, that is my point. Why does known poison have to be in medicine at all? It cannot be good for the human body in any amount. I believe the government should not approve medications with poison in it. They can make it without those chemicals if they wanted to.
The same thing happened to US veterans in the war with Iraq. The vaccinations caused them to be harmed and the drug companies AND government said it was "Iraq war syndrome." It wasn't until Air Force veterans got the diseases these vaccinations gave and the drug company and government said the same thing AND it was proven the Air Force did not actually go to Irag, all they got was the vaccinations.
Yes, seizures are bad, but adding poison to the medicine does not help them either.
The Food and Drug companies RUN the food and drug administration department. The FDA is not protecting us.
Rusty,
The simple truth is that making and refining most drugs is a very complicated process that requires dilution and re-composition of many different chemicals to arrive at the particular compound that gives the desired effects. Most of these chemicals are used for dissolving different compounds and substances and arriving at titrations, that help to refine the desired components of the medication. Most of them are then removed as much as possible and probably exist in such tiny amounts that they have little to no affect in the final compound. The side effects are in fact created in nearly all cases simply by the drug itself and the body's reaction to that drug which is in reality the necessity of trying to correct a dangerous condition that exists, sometimes a simple chemical imbalance in the organs being treated.
The FDA and the medical profession try to weigh risks against the certainties of a particular disease or condition and determine which is worse. In many cases these medications with severe side effects are used to simply curb the certainty of death of the patient. Sometimes, not often enough unfortunately, they accomplish that until a better solution can be found.
I do not think that the drug industry and the FDA and physicians are the terrible money grubbing organization that many people seem to think they are.
Most are good dedicated people trying to do a nearly impossible job.
Most people live longer, and are much healthier today than ever before because of them.
