  • June 26, 2025, 02:11:23 PM
Author Topic: Pictures of Bi-Slob ARF (yawn....yawn.....snore)  (Read 1640 times)
Offline Keith Spriggs
    • khspriggs
« on: May 13, 2007, 10:25:54 PM »
Well, I got the Bi-Slob ARF completed today. I was reluctant to post any pictures because if you have seen one you have seen em all. Not much chance for originality here. I did make the fuel tank and extend the soft copper tubing over flow all the way out the bottom, which seemed to work out pretty good. I thought that the Brodak ARF was pretty well built and finished and I was surprised at the quality and amount of hardware. Going flyin tomorrow.
Re: Pictures of Bi-Slob ARF (yawn....yawn.....snore)
« Reply #1 on: May 14, 2007, 09:02:11 AM »
It looks great to me.  We are going to have to get together with the Slobs.  Maybe at Topeka with Jim & Melvin.  Had mine hanging for at least 15 seconds the other night.  Seemed like an eternity.  They are a blast and maybe it will help me hang my carrier.  Later,  DOC Holliday
Offline Bob Disharoon
« Reply #2 on: May 14, 2007, 03:34:02 PM »
Very nice, Keith..did you have to extend the needle on the Fox to make it accessable?..thanx, H.D.
    • khspriggs
« Reply #3 on: May 14, 2007, 10:56:54 PM »
Yes, I extended it about 5/8 inch using a piece of speedometer cable so it would have a little flex, and a couple of brass sleeves with one end of the sleeve drilled to fit the cable and the other half drilled to fit the needle valve. Everything silver soldered together.
    • khspriggs
« Reply #4 on: May 14, 2007, 11:03:41 PM »
That sounds like a good idea.  Four of us flew for 4 or 5 hours this afternoon. It was a little windy so I didn't try the Bi-Slob. Had a lot of fun with the Flite Streak and Tomahawk anyway.
Offline Leroy Heikes
  • ACE
« Reply #5 on: May 16, 2007, 10:34:02 AM »
I have discovered my Bi SLob loves the wind! The more the wind there is the more fun it is to fly. I let the slob sit until the wind has grounded all of the other planes, and then when everyone is getting ready to leave I start up the Bi Slob and fly. I had a good hang last Sat and the engine quit. let it fall out the bottom and recovered into a perfect landing.  #^ #^ #^
Leroy
Offline Joey Mathison 9806
« Reply #6 on: May 21, 2007, 07:38:01 PM »
get your tail out of the dirt you slob   H^^
200 mph man ama#9806 joey mathison
Offline jetbill40
  • The fast one
    • jetbill products
« Reply #7 on: May 25, 2007, 04:31:50 PM »
I must say Slobbing is fun . One thing you can do is take some 1/4 square balsa and put it on both sides of the rudder. I get mine to hang then work the elevator back and forth and it slowly falls to the groung and lands then rolls to a take off again.   Jet Bill
William Capinjola
