Whats a MBZ , will the alloy V8 dropp in it .
That ' Auto Mo-bile ' by the way .
Indeed , Yr Average stunt ship should fit in the boot of a Hartop , as they say . Dunno if the Magnum or Dusters boots as big ? Should fit 3 or 4 easy , actually . WHICH WAS THE IDEA , In the first place .
AND you can strech out across the back seat , for a nap . No trouble .
Thinking , Alignment varies to suit shocks & such , a touch . Point Being , you can fine tune the road holding . Rather'n the tail wagging the dog . Theyll hold attitude , into a curve , and you can get the boot in at the apex .
Earlier ones , the body roll - the outer front'd toouch the bumpstop , and load up that tyre . So theyed rock & plow , on & off . pushed . Whereas you can eliminate that no sweat , then you can get the boot in instead Bloke racing a 360 Charger ( the aussie one , Vs a V8 Falcon & a V8 Holden ( G.M. ) the right of the straight , around the ton
He went through touched it once . once or twice .
Twice everytime but that ,
and when it didit thrice .
There at that half the two hour production race . pilot has to ease off each time and bring it on as it settles .
Through here , into a tighter left .
Bathurst at the Bottom of Conrod , they Do it hard twice , plowing . every time .I wouldnt want to wait till I was on the straight , to gas it !
They woulda won if theyed sorted that , theyd save whole seconds ALL OVER the PLACE .
The V8 is lower C G & Cr of mass further aft . Muscle . 145 mph ? Hemi six . Stock spec. Seen a channeled one he said ran 160 , timed . Bigger carbs & such .
440 is 500 easy on Gas . 1000 on methanol . 2000 on Nitro . A Black one , anyway . But Methanol 7 10 5 nitro should be good for 1000 or 1100 . safely . Horsepower . Aim was 250 NZLSR .
The Tail heavy 911 when he tried it swapped ends . He coulda ended in the canal . Rough Road , Contact front skewed it flicked and spat loose . WHEREAS the Nose Heavy ' Dodge ' ll Run straight !
And I thought a D B was a aston Martin .
Youd think It'd be compulsary for everyone to own a real car . These modern things are mostly optically repungeant ! Largely comercial marketing intrests get the policy makers in a arm lock , Darn statistics .
Id've thought Paul wouldve done it electric ! .
just kidding .
But Its a hold out if the hysterical faschists demand electrickery . plenty of conversions've been done .
Saw a 61 Tank Fairlane Two door on the mountain months back . thought " That'd carry enough batteries to get across the Nullabor ".
