???I am definitely planning on dual battery packs, two small ones, one in the handle to drive the controller, the other in the plane to drive either a throttle servo, or speed control for electric. A 6v, 150 mAH pack in the handle, and a 4.8 v, 50 mAH in the plane should do the job. Charge them up between flights!
Currently, (ooh, bad pun, sorry) I am thinking of a single braided line with a couple of wipes of urethane, and a solid uninsulated line, both wiped down with dri-lube. Minimize the chance of breaking down the insulating layers!
The goal, of course, is high reliability, minimum control drag, and long life.
