  • July 30, 2025, 05:20:23 PM
Author Topic: New plan: Bob Gieseke’s 2003 Bear: Update 1/25/2025  (Read 14045 times)
Offline SteveMoon
    • www.ultrahobbyproducts.com
« on: January 08, 2025, 09:49:58 AM »
I am almost finished drawing/inking/lettering plans of
Bob Gieseke’s 2003 Bear. See my post on the
Ultra Hobby Products tab in the Vendor’s Corner.
Thanks, Steve Moon
As of 1/25/2025 the plans for Bob Gieseke's 2003 Bear are
available for purchase.
Check the Vendor's Corner for info.
« Last Edit: January 17, 2025, 11:54:25 AM by SteveMoon »
Re: New plan: Bob Gieseke’s 2003 Bear
« Reply #1 on: January 08, 2025, 12:21:01 PM »
+1...
Offline SteveMoon
Re: New plan: Bob Gieseke’s 2003 Bear: Update 1/25/2025
« Reply #2 on: January 17, 2025, 11:55:15 AM »
Plans are ready!
« Reply #3 on: January 17, 2025, 02:43:08 PM »
Moolah sent.
Thanks Steve
Offline SteveMoon
« Reply #4 on: January 17, 2025, 05:43:22 PM »
Thanks Dave
Offline Russell Graves
« Reply #5 on: January 17, 2025, 08:06:00 PM »
I just sent $28 for the plans and shipping. The address should be in the PP receipt. Let me know if you need it.
Russell Graves
Online Sina Goudarzi
« Reply #6 on: January 20, 2025, 01:21:49 AM »
Hi Steve,
I sent mine too,
Thank you
sina
Sina
« Reply #7 on: January 22, 2025, 03:43:55 PM »
Hi Steve,
I received the plans today. They look fantastic!
Just wondering how this one flies compared to the 1997 Bear Nobler (which had a slightly lower aspect ratio wing)?
thanks.
Offline Matt Colan
« Reply #8 on: January 22, 2025, 04:17:06 PM »
Hi Steve,
thanks.
A lot better! This is the plane to build and fly
Online James Mills
« Reply #9 on: January 23, 2025, 09:04:36 PM »
Steve,
The plans arrived today, they look great.
AMA 491167
« Reply #10 on: January 24, 2025, 01:11:55 PM »
Mine just arrived today.    Looks amazing!  Thanks Steve.    Will start on it once the current creation is done.
Looks like I’ll be spending as much time on mold bucks and fixtures as on the airplane.   The wing looks like it was designed to be built in a lost foam fixture.   Don’t have one for it.   May have to get creative!
« Last Edit: January 24, 2025, 01:54:44 PM by Dave_Trible »
Offline SteveMoon
« Reply #11 on: January 29, 2025, 08:55:56 AM »
Thanks for the compliments guys.
Dave: Yes, it was built using lost foam jigs. I drew every rib
and half rib using the pieces from the jig. If you can make the
ribs, then the plans show the location of each rib. Lay down the
bottom spar on your building table, jig up the trailing edge,
and go from there.
Offline Doug Moon
« Reply #12 on: February 02, 2025, 09:48:51 AM »
I got a set of the plans too. I have been flying this plane since 2002, I think I have built it 8 or 9 times, and never once had a plan.  ;D ;D  Ya'll better look out now!!  LL~ LL~
Doug Moon
AMA 496454
Dougmoon12@yahoo.com
« Reply #13 on: February 02, 2025, 10:47:59 AM »
Got mine started already....
« Reply #14 on: February 17, 2025, 11:14:54 AM »
It’s gone together pretty well.   Getting the sticky blue today.   Thanks Steve!
Offline Doug Moon
« Reply #15 on: February 17, 2025, 12:25:17 PM »
Dave,
WOW!! do you sleep?  You stated on Feb 2 you were getting started and now it is 15 days later and your about ready to start the finish!  That's awesome.  :o
Looks great.
« Last Edit: February 17, 2025, 12:56:28 PM by Doug Moon »
Doug Moon
AMA 496454
Offline Matt Colan
« Reply #16 on: February 17, 2025, 12:33:35 PM »
Looks great Dave!! You’re gonna like that plane!
« Reply #17 on: February 17, 2025, 12:38:11 PM »
Dave,
WOW!! do you sleep?  You stated on Feb 2 you were getting started and now it is 15 days later and your about ready to start the finish!  That's awesome!
Doug the grass does not grow under my work table.......Just wish balsa trees did.   Being retired in the dead of winter lets miracles happen!
Offline SteveMoon
« Reply #18 on: February 17, 2025, 12:40:00 PM »
Holy cow!! That is some fast building. And it looks great.
« Reply #19 on: February 17, 2025, 12:47:07 PM »
Matt I like it already.  It seems HUGE compared to my other airplanes.   I have no idea how it was possible Bob went for around 60 ounces with this.   My best estimate right now is about 67-68.   Of course wood weight isn't what it used to be.  I did add a bit to it that I felt necessary for my rough grass flying field.   I built it with a regular leading edge to get something to jig the wing to and also to hold the landing gear ply half ribs in solidly.  I also upped the spars from 1/4 sq. to 1/4 x 3/8.  I use 5/32 music wire instead of 1/8 for the landing gear.   Other than that I built it as Steve drew.
Offline Jake Moon
« Reply #20 on: February 19, 2025, 09:13:51 AM »
Dang Dave, you're an airplane factory! It looks awesome.
« Reply #21 on: February 19, 2025, 09:36:06 AM »
Thanks Jake!   I can actually put them out pretty fast-too fast.   I get anxiety when I don't have my table humming along.   I've built three new ones since the Nats.   When you do the same procedures over and over every motion just gets faster.   My fleet is good to go for years....I am going to make a little diversion to absorb time and energy.   I have begun a scale ship and maybe will get going on some OT free flight stuff.   I am out of room for more stunt airplanes.  Those who have been here will attest there are airplanes everywhere in my part of the house and there are six I think in the storage shed I rent to keep the field mower.   Stunt is my first love and I always circle back to building for stunt.    I've followed your projects along-you are doing good work!
« Reply #22 on: March 31, 2025, 10:06:49 AM »
For the Bear lovers here is my finished airplane.   No engine mounted yet ( RO Jett .67 or .76)
« Reply #23 on: March 31, 2025, 10:08:56 AM »
Nudder pic
Offline EricV
« Reply #24 on: March 31, 2025, 10:39:51 AM »
Nice work Dave, looks great, and you finished it crazy fast too!
I won't ask the obvious question since the engine isn't mounted yet... but I'm thinking it at you, really loud in my mind, can you make it out?  :!
Looking forward to flight reports.
EricV
« Reply #25 on: March 31, 2025, 11:46:04 AM »
EricV
I deciphered it Eric......let you know.   Probably won't happen for a few weeks yet.    Getting my P-40 trimmed when the wind lets up for our first contest in May.    So it will likely be after that but yeah I'm eager to see what we have here.
Offline Matt Colan
« Reply #26 on: April 01, 2025, 11:05:13 AM »
Wow Dave that looks fantastic!!! Excellent work! If it flies like any of the other Bears I’ve flown (except the Orphan) you won’t be disappointed!
« Reply #27 on: April 01, 2025, 12:02:48 PM »
Thank You Matt.   I guess you'll have to tell me about the ORPHAN........
Online Jim Hoffman
« Reply #28 on: April 01, 2025, 03:17:15 PM »
That looks great Dave.  I hope it's a big success.
The fuse side area appears to be plenty big.  Line tension should not be an issue!!
Offline Matt Colan
« Reply #29 on: April 01, 2025, 03:22:37 PM »
I’ll let Doug tell you the story about the Orphan.  LL~
My short story with the Orphan is Doug let me fly it. He said it doesn’t do an hourglass…I almost put him out of his misery when I did the hourglass
« Reply #30 on: April 01, 2025, 04:29:05 PM »
Thank you Jim.    I need to go on a diet and lose a few pounds---but maybe I should fly this thing first!  I wish it were a little lighter but I seem unable to accomplish that.   As it was I didn't go heavy with the finish.   It will be about 69-70 ounces.   Strange though that fuselage really is a lot bigger than my standard fair airplanes but the weight is exactly the same.   It really is mostly hollow and thin skinned.  It felt real tender so I doped a layer of carbon veil over the whole thing leaving wide overlaps top and bottom.   It's a much more rigid shell now which I'll need on my bumpy field.  Most of the wood I had available was 7-9 pound with a few sheets of six I scrounged from a couple old kits I have.   Still I think it should be acceptable.
« Last Edit: April 01, 2025, 04:45:46 PM by Dave_Trible »
« Reply #31 on: April 01, 2025, 04:31:28 PM »
Oh my!   I know he will be tell us about how lucky you were...yada yada
Offline Doug Moon
« Reply #32 on: April 03, 2025, 06:17:08 PM »
Dave,
That plane looks great! I won the nats with one that weighed 67oz IIRC. Plus finished 2nd with a 69oz one. As long as it is straight and the power is steady you'll be good to go!
The Orphan is terrible. Started life as a standard 03 bear. A fellow modeler saw it in my garage and made a nice cash offer while it was in just wood. It was the light stuff too. I accepted and then it hung uncovered on his shop wall for 10 years! Then I bought it back thinking hey this will be awesome. I sat on it for a few months but I was really into helicopters at the time so I sold it to another club member and bought a new ESC and Flybarless controller or something. Then a couple of years later I bought it back from him. Then I proceeded to make the needed repairs and finish it. The finish was nice. But there was no red on the plane anywhere so it was behind the 8ball from the get go. The plane would not fly worth a crap. No amount of trim would make any changes to the way it flew. LO position, TW tailW nose weight it just sucked. It was light above 45 and dead up top. I like to think I can make a plane fly pretty good but this thing was just off. I checked the elevators and they seemed to have a little warp in them. I cut them off and built and finished new ones. It flew better but still NOT GOOD. I got sick of messing with it. I gave it to the original guy that bought it from me all those years ago. He named it the orphan. He has lots of good names for all of our planes. Salvage Title, The Big Spaghetti and many more.  He cut the flaps off and made new ones. It flys better, manageable, but I still hate it. I wondered the stunt wilderness in darkness for years without a GOOD plane. But now I have a rig (Bear) that is Tip Top.
When Matt flew the orphan I set it on a pretty rich needle on accident but he managed to work his way through the pattern. He did not have good reviews of the plane. Hahahaha.
Doug Moon
AMA 496454
« Reply #33 on: April 03, 2025, 07:54:56 PM »
Dave,
Doug thanks and thanks for the Orphan run down.   I had one of my early Desperados that was like that.   It took off to somewhere unknown every time I pulled the second turn of the hourglass.   Never really did sort it out.   It's long gone now but I wonder if the fuselage had a strange hook in    it.   Couldn't find anything else.   It has always seemed that you get lucky-  one out of five or six airplanes is just magic from the get go- the rest are OK but a little average and one is a turd.
Offline Doug Moon
« Reply #34 on: April 04, 2025, 06:47:04 AM »
THIS IS SO TRUE!!!  Every once in a while you find that perfect combo and BOOM it just goes where you point it. The rest of them can be a battle. It's madness too when you have built virtually the same plane for 22 years.
Doug Moon
AMA 496454
Offline Jim Svitko
« Reply #35 on: April 04, 2025, 09:24:02 AM »
Has anyone done the Gieseke Bear with a fully sheeted foam wing?  I like foam wings.  I can build faster and not worry so much about keeping it straight.  The weight penalty is something I accept.  I think I can do a Gieseke Bear with foam and have it come out around 68 ounces if I am careful with wood selection, amount of sheeting adhesive, and being mindful of other things that add weight.
One of the best performers I have now is a Gieseke Nobler.  With an LA 46, it is a joy to fly.  A bigger Gieseke Nobler would be better, as the larger planes are not so jumpy and can handle more wind.
I have a RO Jett 67 now but it is destined for another plane that is under construction.  But, I am pretty sure Dub would be able to build another one for me if I ordered one.
Offline EricV
« Reply #36 on: April 04, 2025, 11:09:58 AM »
I've done built up, sheeted built-up... and used a bunch of sheeted foam wings too (non-Bear variety, but large piped ships nonetheless). To be honest, I think you can build just as light with sheeted wings because of a couple of factors... 1) you don't have dope/filler going through the silkspan and building up on the other side. 2) you can bear down and block sand a sheeted wing much easier and more evenly with less worry of sanding through. If you are careful in your color scheme and paint methods, you can net a very light sheeted wing all up weight. I've seen plenty of chunky monkey built up open bay wing planes, so there is definitely more at play than just the bays.
When sheeting a built-up wing, yes, you can and most likely will eventually get some starved horse effect to it over time if you look close against the light. But who cares? I sure don't, doesn't bother me in the least, and who knows, it might even help act as a VG to some extent, and sure looks better to me than all those plastic doodads on a wing that you will inevitably knock off by mistake loading in and out of your car on appearance judging day.  ;) Sheeted foam is probably the most durable for people prone to hangar rash and has the least amount of flex but sheeted built up is potentially lighter. Ya picks your poison and live or die with it, heh.
EricV
« Last Edit: April 04, 2025, 12:06:48 PM by EricV »
Offline Tom_Fluker
« Reply #37 on: April 14, 2025, 11:18:02 PM »
Dad and I learned that over several different fleets.  Build 10 - 1 is great, 8 are good, 1 is never right.  All built at the same time, the same way.  Go figure.  Interesting thing is that it happened multiple times, not just on one set of 10.
Offline Tom_Fluker
« Reply #38 on: April 14, 2025, 11:19:11 PM »
With these great plans and Jake's new found ability to laser cut parts, is a short kit in the works?
Offline SteveMoon
« Reply #39 on: April 17, 2025, 06:29:26 PM »
Great looking plane Dave! Hope to see it at the Nats.
« Reply #40 on: April 17, 2025, 06:45:07 PM »
Thank you Steve.   I got one test flight in the other day.    Has a completely new engine,  pipe, prop and everything so took it easy and got off with about a 5.6 lap time-slow- but still it felt great,   held the lines well,  was tracking rounds pretty well and went through some soft square corners smoothly so I think we are in good shape.   This wind here right now is a butt every day but maybe it will improve soon and I will sort it out along with a couple other new ships and I'll make some Nats choices.   So far I think this one is a keeper!    Thanks Steve for the drawings.
Offline Ralph Fichtl
« Reply #41 on: April 17, 2025, 09:18:46 PM »
What engine/pipe set up did you go with Dave?
« Reply #42 on: April 18, 2025, 06:10:44 AM »
Ralph It has the RO Jett. .67 in it right now but the .76 is interchangeable .  The pipe and prop  (and tank) are my own.   The pipe is the new full wave pipe.
« Reply #43 on: June 05, 2025, 02:03:32 PM »
Hi Jim,
Sorry I am late about posting this.  I have gotten with Tom Dixon and his not able to make a foam wing for the Bear 2003  which I have received.  Very nice wing.  He also made a Blue Max Eternal foam wing for me.
Weight of both cores are 115 grams.
Ralph
Offline Pepe Llopis
« Reply #44 on: June 06, 2025, 06:12:04 AM »
Cutting ribs, mine will be electric.
